How can I run this eqation (GARCH)
Posted: Thu Mar 05, 2009 12:28 am
by pedcheng
Hi ,
I would like to ask how can I run this equation
Rit = α + µσt2 - (φ0 + φ1σt2) Rit-1 + εt
the model use GARCH(1,1) with GED
I try to put it in the mean equation but dont know how to
deal with "φ0 + φ1σt2) Rit-1" term
Thanks in advanc
Re: How can I run this eqation (GARCH)
Posted: Thu Mar 05, 2009 9:39 am
Could you define your terms a bit?
Are φ0 and φ1σt2 coefficients?
Is φ1σt2 a single term, or is it actually φ1*σt2
Posted: Thu Mar 05, 2009 9:32 pm
by pedcheng
φ0 and φ1 are coeffients but σt2 is conditional variance
so the term (φ0 + φ1σt2) Rit-1 is
(coefficient + coefficient * conditional variance) * Rit-1
I try to use ARCH-M menu when I run equation using GARCh model
but it only put the term " σt2 " in my equation, I dont know how to put this " σt2 " to multiply with Rit-1
Guess this will help you
Posted: Fri Mar 06, 2009 5:10 pm
by Gene
EViews doesn't handle "non-standard" GARCH in Mean specifications.
Here is one solution:
- You can estimate your garch model without the garch in the mean part.
- Save the conditional variance.
- Then estimate you model again this time with the conditional variance saved from the previous estimation in the mean.
- If you want you can save the cond. variance again and then re-estimate the garch again. You can keep doing this until the log likelihood doesn't change much.
For another solution, you can set and estimate the model up in LogL.
Posted: Sat Mar 07, 2009 7:21 am
by pedcheng
thanks QMS Gareth , Gene
I will try it by the way you told me.
Posted: Tue Mar 10, 2009 6:20 am
by pedcheng
How can I run the model in LogL?
thanks
