getting s.e. from ridgereg.prg
Posted: Thu Oct 20, 2011 12:18 pm
by phs
I use EViews 7.2 with the add-in ridgereg.prg (http://www.eviews.com/Addins/addins.shtml)
I would like to have help with modifying the code in ridgereg.prg (see the attached code) so that I can OBTAIN STANDARD ERRORS from the estimated slope coefficients in the ridge regression model. As it is now, the add-in only provides coefficient estimates.
include .\ridgelib.prg logmode +addin %sample = @pagesmpl %origsmpl = %sample if @len(%args) then %dep = @word(%args,1) %regs = @wmid(%args,2) %lambda = @equaloption("L") if @len(%lambda)=0 then %lambda = "0" endif else %dep = "" %regs = "" %lambda = "0" !result = @uidialog("caption", "Ridge Regression", "edit", %dep, "Enter a dependent variable", "edit", %regs, "Enter a list of regressors (a constant will be automatically added)",250, "edit", %lambda, "Enter a value for the biasing constant", "edit", %sample, "Sample") if !result = -1 then stop endif endif 'check valid value for lambda !l = @val(%lambda) if !l = NA then @uiprompt("Invalid value for the constant") stop endif 'check valid series name for dep if @len(%dep) = 0 then @uiprompt("Please enter a series name for the dependent variable") stop endif if @isobject(%dep) = 0 then %msg = %dep + " is not a valid series in your workfile" @uiprompt(%msg) stop endif if {%dep}.@type <> "SERIES" then %msg = %dep + " is not a valid series in your workfile" @uiprompt(%msg) stop endif 'check valid regressors if @len(%regs) = 0 then @uiprompt("Please enter a list of regressors") stop endif setmaxerrs 2 %gname = @getnextname("_g") group {%gname} {%regs} if @lasterrnum>0 then d(noerr) {%gname} @uiprompt( "Invalid list of regressors") stop endif 'check sample smpl {%sample} if @lasterrnum>0 then d(noerr) {%gname} @uiprompt( "Invalid sample") smpl {%origsmpl} stop endif %tab = "results" if @isobject(%tab) then %tab = @getnextname("results") endif table {%tab} call ridgetab({%tab}, {%dep}, {%gname}, !l, %sample) show {%tab} smpl {%origsmpl} d {%gname} 'on input tab should be the table to contain output. Y is the dependent variable, x is the group of regressors, lambda is the bias constant, and smplstr is the input text for the sample subroutine local ridgetab(table tab, series y, group x, scalar !lambda, string %smplstr) vector bcoef vector bridge !R2=0 vector vifs series smplser = 1 call ridgereg(bcoef, bridge, vifs, !r2, y, x, !lambda, smplser) %obs = @str(@obs(smplser)) !row=1 tab.setwidth(1) 19 tab.setwidth(2) 10 tab.setwidth(3:4) 11 %depstr = "Dependent Variable: " + @upper(y.@name) tab(!row,1) = %depstr tab.setjust(!row,1) left !row = !row + 1 %title = "Ridge Regression" tab(!row,1) = %title tab.setjust(!row,1) left !row = !row + 1 %datestring = "Date: " + @datestr(@now,"MM/DD/YY") + " Time: " + @datestr(@now,"HH:MI") tab(!row,1) = %datestring tab.setjust(!row,1) left !row = !row + 1 %smpl = "Sample: " + %smplstr tab(!row,1) = %smpl tab.setjust(!row,1) left !row = !row + 1 %ob = "Included observations: " + %obs tab(!row,1) = %ob tab.setjust(!row,1) left !row = !row+1 %lambda = "Lambda: " + @str(!lambda) tab(!row,1) = %lambda tab.setjust(!row,1) left !row = !row+1 tab.setlines(!row, a, !row, e) +d !row = !row+1 tab(!row,1) = "Variable" tab(!row,2) = "Raw Ridge" tab(!row,3) = "Std. Ridge" tab(!row,4) = "V.I.F" !row = !row+1 tab.setlines(!row, a, !row, e) +d !row = !row+1 for !i=2 to x.@count %n = x.@seriesname(!i) tab(!row,1) = %n tab(!row,2) = bcoef(!i) tab(!row,3) = bridge(!i-1) tab(!row,4) = vifs(!i-1) !row = !row+1 next tab.setlines(!row, a, !row, e) +d !row = !row+1 tab(!row,1) = "R-squared:" tab.setjust(!row,1) left tab(!row,2) = !r2 endsub
Re: getting s.e. from ridgereg.prg
Posted: Thu Oct 20, 2011 1:10 pm
The Ridgereg calculations currently do not calculate standard errors at all, so you'll have to program up the calculations yourself. The routine that calculates ridgereg itself (in the file ridgelib.prg) is pretty simple.
Posted: Thu Oct 20, 2011 1:43 pm
by phs
OK, thanks! Can you give some solid hints on how to obtain these standard errors for the slope coefficient estimates? Should I use bootstrapping to obtain the standard errors, or do not you suggest something else? There is group.resample but since I cannot find a group resample (bootstrap in pairs) for matrices, so it is difficult to estimate the ridge by myself and do resampling, since ridge is done by matrices. Therefore it is best to modify ridgelib.prg and save the standard errors in some way.
Please be as concrete as possible on where and how to change the code. I want to see if the estimated slope coefficient is significantly different from zero.
Ridgelib.prg is attached below:
' ridge regression (following Neter, Kutner, et al, p. 411-413) ' on input: ' y - dependent variable ' x - group consisting of independent variables (including C if desired) ' lambda - ridge adjustment ' smplser - a series equal to 1 at every observation you want to use. ' on output: ' b - coefficient estimate ' bridge - standardized coefficient estimate ' vif - variance inflation factors ' r2 - r-squared subroutine local ridgereg(vector b, vector bridge, vector vif, scalar !r2, series y, group g, scalar lambda, series smplser) local smpl ' drop missing observations smpl if y<>na and @rnas(g)=0 and smplser=1 series temp = 1 smplser = temp !obs = @obs(y) !obsm1 = !obs - 1 ' get a modified version of the original group after dropping the constnat group tempx g tempx.drop c ' compute the ridge regression and standardized ridge regression coefficients group tempyx y tempx sym ss = @cov(tempyx)*!obs ' sum-of-deviations from mean sym xx = @subextract(ss, 2, 2) ' centered x'x matrix xy = @subextract(ss, 2, 1, @rows(ss), 1) ' centered x'y vector dscale = @getmaindiagonal(xx) ' diagonal scale sym dd = @makediagonal(@epow(dscale, -.5) ) ' diagonal scale weighting matrix vector btemp = dd * @inverse(dd*xx*dd+ lambda*@identity(@columns(xx))) * dd * xy ' get ridge regression coefs vector bridge = @makediagonal(@epow(dscale, .5)) * btemp / @sqrt(ss(1)) ' get standardized ridge regression coefficients matrix pmat = @inverse(dd*xx*dd + lambda*@identity(@columns(xx))) * dd*xx*dd * @inverse(dd*xx*dd + lambda*@identity(@columns(xx))) vif = @getmaindiagonal(pmat) ' final adjustments to handle c coefficient and to export coefficients in proper order group tempx2 c tempx %names = g.@members g.drop {%names} g.add tempx2 vector(g.@count) b !j = 1 !cval = @mean(y) for !i=2 to g.@count b(!i) = btemp(!j) %name = g.@seriesname(!i) !cval = !cval - @mean({%name})*b(!i) !j = !j + 1 next b(1) = !cval 'calculate r-squared call r2(!r2,b,y,g) endsub subroutine local r2(scalar !R2, vector coefs, series y, group g) !meany = @mean(y) !sstot = @sumsq(y -!meany) series residuals = y for !j=1 to g.@count residuals = residuals - coefs(!j)*g(!j) next !ssr = @sumsq(residuals) !r2 = 1-!ssr/!sstot endsub
Posted: Thu Oct 20, 2011 2:14 pm
I have no idea how to calculate standard errors for ridge regressions.
Posted: Thu Oct 20, 2011 3:20 pm
by phs
OK, is there anyone else on this forum with any idea on how to estimate standard errors (or t-stats or critical values) for ridge coefficients?
Posted: Thu Oct 20, 2011 5:16 pm
by phs
Let's say I have generated a series y with 1000 observations.
I want to see how many of these 1000 observations that are negative (like a @ count-if-routine). Is there an EViews routine for this?
Posted: Thu Oct 20, 2011 7:12 pm
smpl if y<0 scalar count = @obssmpl
Posted: Thu Oct 20, 2011 7:42 pm
by phs
Moreover, I would like to do some bootstrapping in pairs (or nonparametric bootstrap). The part with Y.resample y_{%k}_b and Z1.resample Z1_{%k}_b works fine, but when I change to a resampling with gtmp.resample(suffix=_{%k}_b). I want to save with the suffix _{%k}_b just as for y and Z1 resample. group-resampling works fine without the suffix, but not with the suffix (even if I change the suffix just to a couple of letters instead of _{%k}_b)
I get the error message: Number of names does not match number of series in "DO_ GTMP.RESAMPLE(SUFFIX=_003_B)". What am I doing wrong?
'something like: for %k {%vars} series Y = y{%k} series Z1 = x{%k}(-{!xOLSlags}) group gtmp y{%k} x{%k}(-{!xOLSlags}) for !boot = 1 to !bootrepsum gtmp.resample(suffix=_{%k}_b) ' Y.resample y_{%k}_b ' Z1.resample Z1_{%k}_b series DZ1_{%k}_b = @recode(Z1_{%k}_b>0,1,0) if {%k} = 003 then 'hk ridgereg(L={tmp003SChk}) Y_003_b C Z1_003_b DZ1_003_b table temptable=results delete results tabplace(tabcoefs_hk_{%k},temptable,{!boot},1,11,2,11,2) delete temptable etc...
Posted: Thu Oct 20, 2011 9:13 pm
The documentation on group.resample is pretty bad. You cannot supply a suffix (as far as I can tell). You must supply individual names for the series that will be resampled. This you need to do something like:
group.resample name1 name2 name3
