UIRadio bug?
Posted: Thu Oct 06, 2011 3:55 pm
I'm having problems with a program that I've written that randomly crashes Eviews. I wonder if it is a bug because it will operate successfully at times but not at others.
I've attached a short example set of programs,workfile (you also need to creat a database just called "database" which will also generate the same sort of crashes to hopefully illustrate the issue (and have tried lots of alternative versions of the "control program" by placing the rerun the control program lines at different places and using more and less eloquent versions of if statements).
What I want is a program that opens a dialogue box which allows the user to select from a variety of programs to run(ie execute). One of the options includes opening a table (In my actual environment this table allows the users to enter sets of forecast growth rates etc which are then used in later programs to drive forward the variables). If the user opens the table they must then run the "control program" again to continue the process.
The idea is that the user may iterate through the steps multiple numbers of times until they come up with something they are happy with. Usually if I iterate through only once or twice everything works fine. This includes when I select the cancel button to end the program. At other times when I press the cancel button Eviews crashes - even if it is something I have done successfully in the past. Basically the whole thing seems a bit unstable.
Attached are some very short and simple example programs. I recommend modifying the paths in the programs as appropriate and running the example control program. Randomly select the different options (they should all work at any one time) and press cancel at various stages to see if you experience the same program.
Of course I'm ahppy to be pointed to any suggestions around the structure of the "control program" that would prevent the possibility of the crash occurring.
I'll need to add an additional post with 2 more short programs in it.
thanks
Peter
thanks
Peter
