Delete series with zero observations
Posted: Thu Feb 26, 2009 6:40 am
by javiersan
I need to delete all series of an imported file where there are no observations, I have the code below that does not work. Coul you please help?
group g *
for !i=1 to g.@count
if @obs(g(!i)) then delete g(!i)
next !i
Thanks,
Javier
Re: Delete series with zero observations
Posted: Thu Feb 26, 2009 6:41 am
by javiersan
I mean
group g *
if @obs(g(!i))=0 then delete g(!i)
next !i
Posted: Thu Feb 26, 2009 7:00 am
by javiersan
In fact my question is perhaps more generic and it is how to use the @errorcount function so that when one of the objects is alphanumeric it deletes the object.
Thanks,
Javier
Posted: Thu Feb 26, 2009 9:17 am
Something like:
group g*
!firstcount = @errorcount
!temp = @max(g(!i))
!secondcount = @errorcount
if !firstcount<!secondcount then
%name = g.@seriesname(!i)
delete {%name}
endif
Posted: Thu Feb 26, 2009 12:58 pm
by javiersan
Thanks Gareth, really appreciated.
Javier
Posted: Fri Feb 27, 2009 10:44 am
by javiersan
Hi Gareth,
When running the program above I receive an error message like "Bad argument to function in "!TEMP=@MAX(G(1))"
Any clue as to why?
Thanks,
Javier
Posted: Fri Feb 27, 2009 10:52 am
Sometimes EViews programming can be frustrating....
group g*
!temp = @max({%name})
delete {%name}
endif
Posted: Fri Feb 27, 2009 11:57 am
by javiersan
Thanks, the program commands are now fine, unfortunately when an imported series has zero observations EViews defaults its type to "alpha" and gives the following error message: "Alpha [series name] sent to function which operates on a matrix "!TEMP=@MAX([series name])". My error threshold is probably 1, how do I increase it?
Regards,
Javier
Posted: Fri Feb 27, 2009 12:01 pm
When you run a program, the run dialog lets you set the error threshold
Posted: Fri Feb 27, 2009 12:07 pm
by javiersan
Oops... I've pressed the run botton hundreds of times and did not pay attention... Thanks.
Posted: Fri Feb 27, 2009 12:21 pm
by javiersan
Actually, is there a way of increasing the error counter via a command in a program? Or can I only increase the counter manually when pressing run?
Thanks again,
Javier
Posted: Fri Feb 27, 2009 12:31 pm
You can only change it via the dialog, but note that you can change it permanently by selecting "make this the default execution mode", so that you won't have to change it every time you run the program.
