Importing data from Excel without seeing the values
Posted: Wed Sep 21, 2011 2:20 pm
Hello all,
In Eviews 7 I have the following problem. I import Excel data via the "Foreign data as workfile" method. When doing so I encounter the problem of not seeing the values. Instead I get only NA's everywhere. Strangely enough I can make graphs and run regressions even though the values are not visible to me (so Eviews has clearly imported them from Excel properly, but it somehow fails to show them to me).
I have tried changing the Excel workbook version (97-2003) and I've also tried to change the decimal values (commas and thousand seperators etc.), all to no avail.
I should also note that when trying to manually insert values in the cells, it does not work (I know that I have to press edit first).
Perhaps someone knows how this problem can be solved? Thanks in advance
