Degrees of Freedom
ifu06636
Degrees of Freedom
Postby ifu06636 » Tue Sep 13, 2011 5:36 am
I am aware that I can do this in eviews, but i wanted to check how do i actually decide the degrees of freedom when doing a chi square test.
i have a very simply mean equation of Returns = Constant + Residuals of conditional mean
The variance equation is more complex and I have 6158 observations, So is my degrees of freedom n-1 i.e. 6157?
I guess not but Im not certain, would someone be able to help, Im sure its a simple answer!
Re: Degrees of Freedom
Postby EViews Glenn » Tue Sep 13, 2011 10:10 am
A chi-square test for what?
And for what purpose do you wish to compute the d.f.?
ifu06636
Postby ifu06636 » Tue Sep 13, 2011 12:16 pm
Hi, apologies I should have been more specific.
It is to do a white test, for homoskedasticity before doing a GARCH model,
I am not sure how to find the degrees of freedom for the LM Stat to use with a table
Postby startz » Tue Sep 13, 2011 2:15 pm
If you do View/Residual diagnostics/Heteroskedasticity you get the chi-squared statistic and EViews tells you the degrees of freedom
ifu06636
Postby ifu06636 » Fri Sep 23, 2011 6:24 am
Is there a specific way in which i should be setting the Lag lenth for testing for Arch effects, Specifically the LM Stat?
