Problem with if statement
miksterz1
Postby miksterz1 » Mon Sep 12, 2011 7:01 am
I am having a problem with a ridiculously routine task. I am trying to execute an if statement of the following type
series check = @isna(forex) if check=1 then series m = 1 endif
I don't actually want to create a series 'm' that equals 1, but have shown that for simplicity. When I run this code, eviews does not create the series 'm' at all. The variable 'check' is a dummy so it always equals either 0 or 1. However. within the if statement, eviews doesn't seem to be reading the 1s in the series. If I add another line of code 'else series m = 0' it does create a series m but it always equals 0.
So basically, for some reason eviews thinks the condition is never true when in fact it is true in many periods.
Re: Problem with if statement
Postby startz » Mon Sep 12, 2011 7:25 am
The if statement doesn't work that way in EViews, which can be confusing. Try
series m = @recode(check,1,0)
miksterz1
Postby miksterz1 » Mon Sep 12, 2011 7:33 am
Thanks, startz. That did work, though I probably should have been more specific about what I am trying to do (I think your solution only tackles this particular example).
I want to create a conditional statement that says when forex=na, replace the na with whatever the last actual value was of forex.
The way I tried doing this is to create the dummy 'check' which equals 1 when forex=na and then refer to it.
Postby EViews Gareth » Mon Sep 12, 2011 8:10 am
forex = @recode(forex=na, forex(-1),forex)
miksterz1
Postby miksterz1 » Mon Sep 12, 2011 11:03 am
Thanks, Gareth!
