GMM error: "log of a non positive number"
Hi, I am trying to estimate Euler equations by GMM and I receive the error message "log of a non positive number". Does anybody know how to resolve this? I've attached the workfile. Any help is seriously appreciated!
- gmm.wf1
- (31.2 KiB) Downloaded 606 times
Re: GMM error: "log of a non positive number"
Your variable congr has negative values. For some values of an exponent, a power of a negative number isn't defined. (square root of -1, for example). You might try changing starting values of the parameters, but I wouldn't be too optimistic.
How did u perform GMM estimation for Euler equation using eviews?
I need to khow that urgently! :(
If it's really urgent, you might take a look at the extensive documentation on GMM in the help system.How did u perform GMM estimation for Euler equation using eviews?
