I have to wectors and I want to group them into matrix. How can I do it?
vectors to matrix
Re: vectors to matrix
Make a matrix of the correct size, then use the colplace function to put your vectors into the matrix.
thank you. And another question. when i try to use yours function. it's said that one of my vectors values are not numerical. How I should convert them to numerical?
suppose, mu vector is MM and I shoul convert him. so how it's decribe with function @val. ?
vectors to matrix
If Mu is a vector, it, by definition, already contains numerical data.
Hi, eviews.
I would also like to use colplace function to insert a column vector in the the matrix. However, it requires me to insert a column vector with the same number of rows as the matrix.
So what if some of my column vectors is shorter than the the matrix? How can I insert them into the "larger" matrix? Thank you.
matplace
