coefficient covariance matrix panel least squares
Posted: Fri Aug 12, 2011 1:27 am
Hi everybody
I'm using Eviews 7.2. I'm more of a practical econometrician and not that proficient in the technical background.
My sample: N (202) > T (19).
Notation: i = 1,...,N (cross section), t=1,...,T (time)
I'm doing a panel least squares estimation and I'm using the White period coefficient covariance matrix estimator for robust inference. Is the White period estimator implemented in Eviews the same as the one proposed in Arellano 1987 ("Computing Robust Standard Errors for Within-groups Estimators", attached)? The equation in User Guide II (35.33) looks pretty much the same as the equation in the paper (4), except for:
- the degress of freedom adjustment in Eviews
- the two additional sigma signs in the terms sum(Xi'Xi) in Eviews -> Is sum(Xi'Xi) (in Eviews) equal to X'X (in the paper)?
May I quote Arellano (1987) as the source for the White period estimator implemented in Eviews?
Did I get this right:
- The White period estimator is robust against heteroskedasticity along the cross section dimension for a fixed t: V[uit|X=xit] not equal for different i for a fixed t.
- The White period estimator is robust against autocorrelation along the time dimension for a fixed i.
- For N > T it is common practice to use the White period estimator in favor of the White cross section or White diagonal estimator.
Thanks a lot for advice.
Cheers, Harry
Cheers, Harry
