Combine Matrix
Posted: Thu Aug 11, 2011 8:17 pm
by fitria
Hello
i had a trouble for combining matrix, i have this program :
load "D:\exp_matrix.xls" for %var rand1 rand2 %dep = %var equation eq_{%dep}.arch(1,1) {%dep} c ar(1) ar(2) ma(1) !rsqadj = eq_{%dep}.@rbar2 !aic = eq_{%dep}.@aic !sc = eq_{%dep}.@schwarz matrix (1,3) crits_eq_{%dep} crits_eq_{%dep} (1,1) = !rsqadj crits_eq_{%dep} (1,2) = !aic crits_eq_{%dep} (1,3) = !sc matrix (2,3) crits_eq_all next
i'm curious how to combine 2 matrix in the same matrix. above this, i want to combine matrix crits_eq_rand1 and crits_eq_rand1 in the same matrix, it is crits_eq_all, but how the way i make this happen?
thank you.
Re: Combine Matrix
Posted: Fri Aug 12, 2011 10:52 am
matplace(crits_eq_all, crits_eq_rand1, 1, 1) matplace(crits_eq_all, crits_eq_rand2, 2, 1)
an easier way to do this is to create the CRITS_EQ_ALL at the beginning, and write everything to the !i row of the matrix when you are filling it. That way you don't have to combine things when you are done.
Re: Combine Matrix
Posted: Fri Jun 29, 2018 2:47 am
by shineK
Hi there,
i have several matrix(more that 1000) with monthly frequency and need to combine to one, each matrix have 2 columns(c1 is monthly date, c2 is return), how to combine them all and with one monthly date?
i would like to turn matrix into group, but i can't use mtos because when i imported data i choosed dated regular frequency by daily...
Thank you so much!
Re: Combine Matrix
Posted: Fri Jun 29, 2018 10:00 am
by EViews Matt
Let's take a step back here. EViews can import your data into a monthly workfile. The trick is to indicate that the first column of data should be imported as characters, not a number. You'll then have the option to use that series as the date series for the workfile.
Re: Combine Matrix
Posted: Fri Jun 29, 2018 4:37 pm
by shineK
Hi Matt,
Thank you. I have solved the problem!!! :D
