Reading a csv file into a table
atoch
Contact:
Postby atoch » Tue Jul 05, 2011 4:28 am
Bonjour,
I have a table of metadata stored in a csv file. I'd like to be able to import it as an Eviews table. Is there a way to achieve that using an eviews program ? It is easy to export an Eviews Table into a text file but import does not seems to exist. May be there is a more appropriate Eviews object to store metadata ?
Arnaud Atoch
CSV file content
Variable,Type,Power,Formula_Q,Formula_A,Flag
GDP,GROWTH,9,PGDP*GDPV,convert(averaged),I
CPV,GROWTH,9,ND,convert(averaged),F
Expected result in an Eviews Table
Variable Type Power Formula_Q Formula_A Flag
GDP Growth 9.000000 PGDP*GDPV Convert(averaged) I
CPV Growth 9.000000 ND Convert(averaged) F
Re: Reading a csv file into a table
Postby EViews Gareth » Tue Jul 05, 2011 7:51 am
There isn't an easy way to do this. In general, currently, EViews is not great at reading in meta data.
You have two options. You could either read the csv file in as a new page in your workfile, then figure out some way to get the information back to your original page.
Or you could read the csv file in as a text object, then parse the text object to get the metadata.
memos
Postby memos » Thu Jul 24, 2014 7:16 am
I was looking for an answer to the same question: "how to read text in a csv file into a table?"
However, regarding Gareth's second suggestion, I was not able to figure out how to read a text file into a text object. The text object does not seem to have a "read" procedure. I use Eviews version 8.
Postby EViews Gareth » Thu Jul 24, 2014 7:56 am
text.append
memos
Postby memos » Thu Jul 24, 2014 8:12 am
