Page 1 of 2
Multinomial Logistic Regression (MLR)
Posted: Tue Jun 28, 2011 1:59 pm
by strezise
I am trying to adapt the example MLR in the help guide but keep getting errors.
Basically, I will have 7 categories of dependant variable (1-7), and 5 regressors (2 of which are dummy variables). However, when I try to run the below code I get the error message "B7 is not defined or is an illegal command".
I think I may be getting things very mixed up here!
Any help would be apprciated. Thanks
' declare parameter vector
coef (7) b2
coef (7) b3
coef (7) b4
coef (7) b5
coef (7) b6
coef (7) b7
mlogit.append xb2 = b2(1)+b2(2)*x1+b2(3)+b2(4)+b2(5)+b2(6)+b2(7)*x7
mlogit.append xb3 = b3(1)+b3(2)*x1+b3(3)+b3(4)+b3(5)+b3(6)+b3(7)*x7
mlogit.append xb4 = b4(1)+b4(2)*x1+b4(3)+b4(4)+b4(5)+b4(6)+b4(7)*x7
mlogit.append xb5 = b5(1)+b5(2)*x1+b5(3)+b5(4)+b5(5)+b5(6)+b5(7)*x7
mlogit.append xb6 = b6(1)+b6(2)*x1+b6(3)+b6(4)+b6(5)+b6(6)+b6(7)*x7
mlogit.append xb7 = b7(1)+b7(2)*x1+b7(3)+b7(4)+b7(5)+b7(6)+b7(7)*x7
' define prob for each choice
mlogit.append denom = 1+exp(xb2)+exp(xb3)+exp(xb4)+exp(xb5)+exp(xb6)+exp(xb7)
mlogit.append pr1 = 1/denom
mlogit.append pr2 = exp(xb2)/denom
mlogit.append pr3 = exp(xb3)/denom
mlogit.append pr4 = exp(xb4)/denom
mlogit.append pr5 = exp(xb5)/denom
mlogit.append pr6 = exp(xb6)/denom
mlogit.append pr7 = exp(xb7)/denom
' specify likelihood
mlogit.append logl1 = (1-dd2-dd3-dd4-dd5-dd6)*log(pr1)+dd2*log(pr2)+dd3*log(pr3)+dd4*log(pr4) +dd5*log(pr5)+dd6*log(pr6)+dd7*log(pr7)
' specify analytic derivatives
for!i = 2 to 7
mlogit.append @deriv b{!i}(1) grad{!i}1 b{!i}(2) grad{!i}2 b{!i}(3) grad{!i}3 b{!i}(4) grad{!i}4 b{!i}(5) grad{!i}5 b{!i}(6) grad{!i}6 b{!i}(7) grad{!i}7
mlogit.append grad{!i}1 = dd{!i}-pr{!i}
mlogit.append grad{!i}2 = grad{!i}1*x1
mlogit.append grad{!i}3 = grad{!i}1*x2
mlogit.append grad{!i}4 = grad{!i}1*x3
mlogit.append grad{!i}5 = grad{!i}1*x4
mlogit.append grad{!i}6 = grad{!i}1*x5
mlogit.append grad{!i}7 = grad{!i}1*x6
' get starting values from binomial logit
equation eq2.binary(d=l) dd2 c x1 x2 x3 x4 x5 x6
b2 = eq2.@coefs
equation eq3.binary(d=l) dd3 c x1 x2 x3 x4 x5 x6
b3 = eq3.@coefs
equation eq4.binary(d=l) dd4 c x1 x2 x3 x4 x5 x6
b4 = eq4.@coefs
equation eq5.binary(d=l) dd5 c x1 x2 x3 x4 x5 x6
b5 = eq5.@coefs
equation eq6.binary(d=l) dd6 c x1 x2 x3 x4 x5 x6
b6 = eq6.@coefs
equation eq7.binary(d=l) dd7 c x1 x2 x3 x4 x5 x6
b7 = eq7.@coefs
Re: Multinomial Logistic Regression (MLR)
Posted: Tue Jun 28, 2011 2:07 pm
The first obviously thing you've got wrong is that you've written:
coef (7) b2
When you should have:
coef(7) b2
Other than that, without seeing the rest of the program, it is hard to debug.
Posted: Sun Jul 17, 2011 12:39 pm
by rohanarora78
hi,
i am doing a dissertation on " analysis of determinants of banking crisis " and my instructor told me to use logit model, i don`t know even the basic of it, he told me that put value =1 for crisis and 0 for no crisis and then study the data to predict the banking crisis by studying the past data, can anyone plzz help me on that ???
Posted: Sun Jul 17, 2011 12:55 pm
by startz
Most econometrics text books have a section on logit. The Wikipedia entry for "logistic regression" isn't bad either.
Posted: Thu Sep 06, 2012 5:29 am
by Nas1
Hello!!!
I am totally new on eviews (I am using eviews7) and I am working on MLR. However, i always get an error message stating that I have a "missing values in @LOGL series in the current coefficients..." I am using a panel data. is this message have a connection with the type of data I am using? how to modify the program in case i am using a panel work file??
Please please advise
Posted: Thu Sep 06, 2012 10:27 am
by EViews Glenn
Probably your starting values. Look at the series specified in the @LOGL to see which observations are missing. Then trace back to see where the problems are in the series that are used to construct the @LOGL series.
A search of the forum for starting values should point to other useful tips.
Posted: Thu Sep 06, 2012 11:58 am
by Nas1
thank you so much for fast reply, however, I reviewed my data and I am still getting the same statement. I think there is a missing point I did not understand in the example on Eviews manual and example file concerning the definition of the dd2 and dd3. they post the dummies of d1, d2, and d3 why they did not use these dummies when estimating the @LOGL function and how they estimate the new dummies anyway?? sorry for these silly questions but this example is crucial for me to understand and base my work on it!!
many thanks.
Posted: Thu Sep 06, 2012 2:19 pm
by EViews Glenn
The DD variables are the indicators for the dependent variable. Dummy variables, if you will for which of the multinomial responses is observed.
Posted: Thu Sep 06, 2012 2:58 pm
by Nas1
I am still getting this error statement. May you please take a fast check on this codes. I still dont understand why I am always getting the error message concerning my estimations!! I will upload the WF.
thank you so much!!
load Onepanel
series dummy2 = @recode(emp2=1, 1, 0)
series dummy3 = @recode(emp3=2, 1, 0)
coef(3) b2
coef(3) b3
coef(3) b4
coef(3) b5
coef(3) b6
coef(3) b7
coef(3) b8
coef(3) b9
' true values are
' b2(1) -0.4 b2(2) 1 b2(3) -0.2
' b3(1) -0.4 b3(2) 0.3 b3(3) 0.5
' setup the loglikelihood
logl Onepanel
Onepanel.append @logl logl1
' define index for each choice
Onepanel.append xb2 = b2(1)+b2(2)*dc+b2(3)*dcg +b2(4)*gdp+b2(5)*lvix +b2(6)*vix+b2(7)*ov +b2(8)*std_res+b2(9)*p_c
Onepanel.append xb3 =b3(1)+b3(2)*dc+b3(3)*dcg +b3(4)*gdp+b3(5)*lvix +b3(6)*vix+b3(7)*ov +b3(8)*std_res+b3(9)*p_c
Onepanel.append denom = 1+exp(xb2)+exp(xb3)
Onepanel.append pr1 = 1/denom
Onepanel.append pr2 = exp(xb2)/denom
Onepanel.append pr3 = exp(xb3)/denom
Onepanel.append logl1 = (1-dummy2-dummy3)*log(pr1)+dummy2*log(pr2)+dummy3*log(pr3)
for !i=2 to 3
Onepanel.append @deriv b{!i}(1) grad{!i}1 b{!i}(2) grad{!i}2 b{!i}(3) grad{!i}3
Onepanel.append grad{!i}1 = dummy{!i}-pr{!i}
Onepanel.append grad{!i}2 = grad{!i}1*gdp
Onepanel.append grad{!i}3 = grad{!i}1*lvix
Onepanel.append grad{!i}4 = grad{!i}1*vix
Onepanel.append grad{!i}5 = grad{!i}1*ov
Onepanel.append grad{!i}6 = grad{!i}1*std_res
Onepanel.append grad{!i}7 = grad{!i}1*p_c
Onepanel.append grad{!i}8 = grad{!i}1*cab
Onepanel.append grad{!i}9 = grad{!i}1*dc
Onepanel.append grad{!i}10 = grad{!i}1*dcg
equation eq2.binary(d=l) dummy2 c dc dcg gdp lvix vix ov std_res p_c
b2 = eq2.@coefs
equation eq3.binary(d=l) dummy3 c dc dcg gdp lvix vix ov std_res p_c
b3 = eq3.@coefs
' do MLE and display results
Onepanel.ml(showopts,m=3888, c=1e-5)
show Onepanel.output
Posted: Fri Sep 07, 2012 8:43 am
by Nas1
please advice, is the panel data have any relation with the failed estimation? the betas are not estimated!!! Any help would be appreciated. Thanks
Posted: Mon Sep 10, 2012 2:04 pm
by EViews Glenn
Data?
Posted: Tue Sep 11, 2012 5:09 am
by Nas1
Here is the data; many thanks!!!
Posted: Tue Sep 11, 2012 1:35 pm
by EViews Glenn
The series EMP2 does not exist. Neither does EMP3.
Posted: Wed Sep 12, 2012 4:07 am
by Nas1
I uploaded the wrong file, sorry for this mistake!!!Please recheck this attached file for the failed estimation.
Best regards,
Posted: Sat Sep 15, 2012 4:18 am
by Nas1
please advise!!!
