How to correct a Dummy variable for Autocorrelation?
Posted: Tue Feb 10, 2009 12:34 pm
by Martin B
Hi at all!
This question actually follows from another thread. However, I thought it would be useful to post it separately.
I have the following regression equation system:
y_1t = a + b_1*x_t + c*z_1t y_2t = a + b_2*x_t + c*z_2t
Now, if I want to correct for autocorrelation, I can write (e.g. for the first equation)
y_1t = a*(1-r) + b_1*(x_t-r*x_{t-1}) + c*(z_1t-r*z_1{t-1}) + r*y_1{t-1}
Now, a dummy variable is included in the regression system of the sort
y_1t = a + b_1*x_t + c*z_1t + g*D*z_1t y_2t = a + b_2*x_t + c*z_2t + g*D*z_2t
Here, D can take either 1 or 0 and g is the coefficient before the Dummy variable.
My question is: how can I correct the Dummy variable for possible autocorrelation? Is it even important? The problem is: it is a dummy indicating 1 if the observation is after a certain date and 0 if the observation is before a certain date. So, after some time, all observations will have D=1.
I thank you very much.
Kind regards
M
Re: How to correct a Dummy variable for Autocorrelation?
Posted: Tue Feb 10, 2009 2:01 pm
by startz
Hi at all!
Kind regards
M
You treat the dummy variable exactly like any other rhs variable.
Posted: Tue Feb 10, 2009 2:19 pm
by Martin B
Hi Startz
Thank you for your answer.
So I can do the following?
y_1t = a*(1-r) + b_1*(x_t-r*x_{t-1}) + c*(z_1t-r*z_1{t-1}) + r*y_1{t-1} + g*D*(z_1t-r*z_1{t-1})
Posted: Tue Feb 10, 2009 2:24 pm
by startz
Hi Startz
Not quite. My answer was a little careless. You need to treat D*z_1 as the RHS variable.
y_1t = a*(1-r) + b_1*(x_t-r*x_{t-1}) + c*(z_1t-r*z_1{t-1}) + r*y_1{t-1} + g*(D*z_1t-r*D{t-1}*z_1{t-1})
Posted: Tue Feb 10, 2009 2:47 pm
by Martin B
Thank you very much!
I already tested in Eviews. Coefficient before the dummy proved to be statistically insignificant. But at least I know now...
Kind regards
M
