Chow test in Seemingly Unrelated Regression
Martin B
Postby Martin B » Tue Feb 10, 2009 9:51 am
Hi at all!
I have a time sample 1 to T1 (1/2006 to 6/2007) and a second time sample T1 + 1 to T2 (7/2007 to 12/2008)
I estimate the following as a system of seemingly unrelated regressions:
Sub-Sample from 1 to T1: (error terms denoted by u)
y_1t = a + b_1*x_t + c*z_1t + u_1t y_2t = a + b_2*x_t + c*z_2t + u_2t
Sub-Sample from T1+1 to T2: (error terms denoted by v)
y_1t = d + f_1*x_t + g*z_1t + v_1t y_2t = d + f_2*x_t + g*z_2t + v_2t
Hereby, the coefficient a in the first period is denoted d in the second, the same is true for b and f and for c and g.
Now what I am interested in: I want to now if the coefficient c is significantly different from g. Thus, if the variable z is priced different in the two sub-periods.
I know that in a normal regression this can be done by a Chow-Test. Is there a possibility to conduct a Chow-Test in a system of seemingly unrelated regressions?
I thank you very much.
Kind regards
M
Re: Chow test in Seemingly Unrelated Regression
Postby EViews Gareth » Tue Feb 10, 2009 9:59 am
EViews doesn't have a Chow test for SUR built in, but it is relatively simple enough to do one yourself - just estimate over both time periods (i.e. 1 to T2) and include dummy variables for the T2 period.
Martin B
Postby Martin B » Tue Feb 10, 2009 10:32 am
Hi Gareth
Thank you for your reply.
So you are suggesting that I estimate a SUR model over the whole time period.
But how exactly can I then conduct the Chow-Test? I mean, if I have two regressions in the system, I have two error terms and two sums of squared errors. I am not quite sure how I can built the test statistics.
Sorry to bother with so many questions...
Kind regards
M
Postby startz » Tue Feb 10, 2009 10:39 am
Hi Gareth
Kind regards
M
A Chow test is just a test that the coefficients are equal across periods. You can use View/Coefficient tests/Wald to test that the coefficients from the first period equal those from the second period.
Postby EViews Gareth » Tue Feb 10, 2009 10:40 am
Create a dummy variable that is equal to 1 during T1+1 : T2 and 0 during 1:T1. Lets call this dummy DUM.
Then run the following SUR over 1:T2:
y_1t = a + d1*DUM + b_1*x_t + c*z_1t + u_1t
y_2t = a + d1*DUM + b_2*x_t + c*z_2t + u_2t
The t-test on the DUM coefficient (d1) will be a Chow test for the intercept. If you want to do a Chow test on all coefficients, then you'd do:
y_1t = a + d1*DUM + b_1*x_t + d2*DUM*x_t + c*z_1t + d3*DUM*z_1t + u_1t
y_2t = a + d1*DUM + b_2*x_t + d2*DUM*x_t + c*z_2t + d3*DUM*z_2t + u_2t
The Wald test on d1=d2=d3=0 is then a Chow test on all coefficients.
Martin B
Postby Martin B » Tue Feb 10, 2009 11:05 am
Ok, thanks very much.
So if I want to test if the coefficient on the variable z_t is different in the first period than in the second period, I would do:
y_1t = a + b_1*x_t + c*z_1t + d3*DUM*z_1t + u_1t y_2t = a + b_2*x_t + c*z_2t + d3*DUM*z_2t + u_2t
Is this correct?
Question: say, the coefficient d3 proves to be significantly larger than zero (t-statistics). How can I interpret this result? Is it true that in this case the coefficient on z is larger in the second period than in the first period?
Again, thanks...
Postby EViews Gareth » Tue Feb 10, 2009 11:38 am
Right. In fact the coefficient d3 is an estimate of how much bigger the coefficient on Z is in the second period.
Martin B
Postby Martin B » Tue Feb 10, 2009 11:42 am
I thank you very, very much for your most helpful advice!
Kind regards
M
