Using @replace with wildcard
lisacabisa
Postby lisacabisa » Fri Jun 03, 2011 9:56 am
Is it possible to use @replace string function with a wildcard? If not, does anyone have an idea how to do what I'm trying to do?
I am trying to strip off the path information so I have just the Eviews workfile name.
%wfpath = "C:\work\Eviews\q2fy10_sys.wf1"
%wf = @replace(%wfpath,"*\","")
I would expect replacement to remove all characters up to and including the last backslash so that %wf is equal to q2fy10_sys.wf1
Does not seem to work...
TIA
Re: Using @replace with wildcard
Postby EViews Gareth » Fri Jun 03, 2011 10:10 am
No, it doesn't work that way (nor could it, logically).
If you know that your path has 3 slashes in it, then you can use @instr and @mid to do what you want:
%wfpath = "C:\work\Eviews\q2fy10_sys.wf1" %wf = @mid(%wfpath, @instr(%wfpath, "\", 3)+1)
monjoride
Postby monjoride » Sat Jul 02, 2011 2:12 am
and if the path is longer than 3 slashes?
Action Plan Of GSM Repeater
GSM Repeater 900Mhz
Postby EViews Gareth » Sat Jul 02, 2011 11:40 am
%wfpath = "C:\work\Eviews\q2fy10_sys.wf1" %wf = %wfpath !pos = @instr(%wf, "\") while !pos>0 %wf = @mid(%wf, !pos+1) !pos = @instr(%wf, "\") wend
Or something along those lines.
Gardner
Contact:
Postby Gardner » Fri Apr 27, 2012 5:20 am
Hey...
Nice link shared...
Its a great site for getting the information...
Thank you for sharing this great informative stuff here...
_______________
basement dehumidifier
