Bug in @elem?
Bug in @elem?
Postby startz » Wed May 18, 2011 1:27 pm
Is this a bug in @elem, or just a misunderstanding on my part.
series studentToShow = @ceiling(@obsrange*rnd) scalar student = @elem(studentToShow,1)
I get the error message
This is running in an undated workfile.
For what it's worth, all I really want to do is to randomly select one observation from an alpha series in the next step. Maybe there's a better way to do it?
Re: Bug in @elem?
Postby EViews Gareth » Wed May 18, 2011 1:54 pm
Not a bug. @elem requires that the second argument be in quotes.
Of course a better way would just be:
scalar student = @floor(@runif(1,@obsrange))
Re: Bug in @elem?
Postby startz » Wed May 18, 2011 1:58 pm
(a) Thank you.
(b) You're right.
(c) It's not my fault. The documentation reads
@elem takes two arguments: the first argument is the name of the series, and the second is the date or observation identifier.
For example, suppose that you want to use the 1980Q3 value of the quarterly series Y, or observation 323 of the undated series X. Then the functions:
@elem(y, 1980Q3)
@elem(x, 323)
will return the values of the respective series in the respective periods.
Re: Bug in @elem?
Postby EViews Gareth » Wed May 18, 2011 2:06 pm
Yep, I've noticed that before.
Re: Bug in @elem?
Postby startz » Wed May 18, 2011 2:06 pm
Also, are you sure about @floor rather than @ceiling? Or put better, if I want the closed interval [1,@obsrange] do I need
@floor(@runif(1,@obsrange+1))
Re: Bug in @elem?
Postby EViews Gareth » Wed May 18, 2011 2:10 pm
As soon as I posted the code, I thought to myself I wonder if I should change it to add the +1, or should I wait and see if he notices it.
