State space specification
Posted: Sun May 15, 2011 8:59 am
Hi! I have a state-space model estimated from 1996Q1 to 2010Q4. I'm using the following program to run the estimations:
smpl 1996:1 2010:4
sym (4) cov_c
cov_c = @identity(4)
sspace kmc1_r
kmc1_r.append @vprior cov_c
'Ecuaciones de seƱal
kmc1_r.append @signal dl1pib_sa = sv4 + sv1 - sv2
kmc1_r.append @signal dl1ipc_sa = sv3 + [var = 1]
kmc1_r.append @signal dl1itcrm = sv6 - sv7 + sv5
kmc1_r.append @signal tea_rp = sv8 + sv9
kmc1_r.append @signal d1bp = sv11 - sv13 + sv10 + [var = 2]
'Ecuaciones de estado:
kmc1_r.append @state sv1=c(1) * sv2 + c(2) * sv15 + c(3) * sv7 + c(4) * sv14 +[var = exp(c(1))]
kmc1_r.append @state sv2 =sv1(-1)
kmc1_r.append @state sv3 = c(5) * sv3(-1) + c(6) * dl1ipcm + c(7) * sv2 + c(8) * dl1ipc_sa(+1) + [var = exp(c(5))]
kmc1_r.append @state sv4 = c(9) + c(10) * sv4(-1) + [var = exp(c(10))]
kmc1_r.append @state sv5 = c(11) + c(12) * sv10 + c(13) * dl1itcer + c(14) * sv4 + [var = exp(c(3))]
kmc1_r.append @state sv6 = c(15) * sv7 + [var = exp(c(15))]
kmc1_r.append @state sv7 = sv6(-1)
kmc1_r.append @state sv8 = c(16) + c(17) * libor + sv5 + [var = 3]
kmc1_r.append @state sv9 = c(18) * sv9(-1) + [var = exp(c(18))]
kmc1_r.append @state sv10 = c(19) * sv10(-1) + [var = exp(c(19))]
kmc1_r.append @state sv11 = c(20) * sv1+ [var = exp(c(1))]
kmc1_r.append @state sv12 = sv10(-1)
kmc1_r.append @state sv13 = sv11(-1)
kmc1_r.append @state sv14 = c(21) * sv14(-1) + [var = exp(c(4))]
kmc1_r.append @state sv15 = sv9(-1)
kmc1_r.ml
kmc1_r.makestates(t=smooth) k1*
stop
I can't find the error but an error message appears every time I try to run the model. Can anyone help me please?
You can find attached the workfile.
Thanks!.
A.
smpl 1996:1 2010:4
sym (4) cov_c
sspace kmc1_r
kmc1_r.ml
stop
Thanks!.
A.
