Page 1 of 2
GARCH forecasting
Posted: Sat May 14, 2011 12:05 pm
by SevenSeas
Hi there
I am using Eviews 6 "student version". I am working on GARCH forecasting. In forecasting, Eviews is supossed to produce two things:
1- The forecasted time series "conditional mean and conditional variance"
2- The evaluations and the graphs.
My problem is that Eviews sometime only gives the forecasted time series and does not produce graphs, but instead it says "square root of negative number". I do not know how to go about this problem.
Re: GARCH forecasting
Posted: Sat May 14, 2011 2:17 pm
Could you post an example?
Posted: Sat May 14, 2011 3:16 pm
by SevenSeas
Ok
After estimating the GARCH model for the Dow Jones Index return having the oil return included in the mean and the variance, I click FORECAST. Then, I write the series names such as the forecast name, S.E. and the GARCH using Static Forecast. Before clicking ok, I tick the box of Forecast Graph as an option for the output because I want the graphs of the forecast of variance and and the forecast of the mean with +/- 2 S.E. After clicking OK, Eviews gives me an error saying " square root of negative number" and it does not produce the graphs as a result. However, it worked fine with when using different set of data.
I hope this explanation helps clarifying the problem
Regards
Posted: Sat May 14, 2011 3:29 pm
I meant, could you provide an example workfile?
Posted: Sat May 14, 2011 3:43 pm
by SevenSeas
I attached the workfile here. The first 300 observations are for estimation, the last 55 is for forecasting
Regards
Posted: Mon May 16, 2011 12:40 am
by trubador
The problem results from the fact that your garch equation generates negative variances in the forecast period. This is mainly due to change in oil prices, which you use it as an exogenous variable in your variance equation. Although the estimated coefficent value of the "oil" is 0.000767 and is significant for the sample period between 1 and 300, you would estimate an insignificant coefficent value of 0.000322 if you extended the sample to cover the period between 1 and 355. Therefore, either you should consider dropping the oil variable from your variance equation (you already use it in your mean equation) or find a way to ensure the positivity of conditional variance over the forecasting period.
Posted: Wed May 18, 2011 10:40 am
by SevenSeas
That's true, thanks very much for your clarification
Posted: Mon May 30, 2011 7:26 am
by Lyubov
Hello! I have the same problem. But there is no an exogenous variable in variance equation in my specification of model. And when i try to do static forecast i get the error "square root of negative number".
Posted: Tue May 31, 2011 11:16 am
by EViews Glenn
With standard GARCH (not EGARCH), this can happen even if you don't have exogenous variables in the variance equation since the specification doesn't impose positivity. It's analogous to doing a linear least squares regression using in-sample positive data, which doesn't guarantee positivity of the out-of-sample forecasts.
Posted: Sat Apr 13, 2013 11:46 am
by sagga
I am running into the same issue when running GARCH-M, TARCH-M, CGARCH-M models using the interest rate differential (gbpjpy_fx) as the dependent with a constant and the interest rate differential (gbpjpy_int) in the mean equation with the standard deviation in the mean equation. Can anyone give me advice on how to ensure the positivity of conditional variance for my data? This also happens for the specification (gbpaud_fx c gbpaud_int)
I would really appreciate some guidance. Thanks.
Posted: Fri Mar 06, 2015 8:50 am
by econworker
Hi, I have a question regarding the forecasting procedure using a GARCH model. In eviews, If I use a GARCH estimation for the sample size for instance 01/01/2008 to 01/01/2014, and estimate a GARCH model, then I perform a forecasting within this model, for the sample from 01/01/2010 to 01/01/2011...I would like to know that if eviews perform an in sample or out of sample forecast for the series within a GARCH model? as it doesn't require to justify the sample size while changing the forecasting date...
I look forward to hear from you
Posted: Fri Mar 06, 2015 8:55 am
EViews forecasts over whatever sample you tell it to, whether that is in sample or not.
Posted: Mon Mar 09, 2015 4:29 am
by econworker
Thanks, sorry if my question is basic, but would you please tell me what is the difference between:
1. If I my estimation sub-sample is 01/01/2008-01/01/2014 for GARCH estimation, then I perform a forecasting within this model, for the sample from 01/01/2010-01/01/2011,
or
2. If I my estimation sub-sample is 01/01/2008-01/30/2009 for GARCH estimation, and forecast the sample from 01/01/2010-01/01/2011.
the second case is obvious as the sub-sample is divided to estimation sub-sample and forecasting sub-sample, but the first case is not clear for me, as I can not understand how Eviews apply the whole sample data and then forecast a period within that sample. Would you please guide me if in forecasting literature, is this a specific kind of forecasting that I can read about it?
Posted: Mon Mar 09, 2015 5:44 am
by trubador
You should study the difference between static (in-sample) and dynamic (out-of-sample) forecasting. In-sample forecasting is actually the "fit" of your model. Forecasting of an unknown future (hence the name out-of-sample) is something you deal with dynamic forecasting.
Posted: Mon Mar 09, 2015 6:24 am
by econworker
Thanks, I know about in-sample and out of sample forecasting by definition. Out of sample forecasting is obvious, however, I cant find any source that shows how to perform an in sample technically, for example, in my above example, if I use the whole sample to estimate a GARCH equation and then I forecast for a specific date within that equation, is it an in sample forecasting?
Thank you
