How to retrieve function results not stored in matrices?
Posted: Sat Apr 30, 2011 11:36 pm
I'm using the "coint" method for co-integration of the var object and were disappointed to see that the matrix which is supposed to store the results for further processing is very incomplete. for example, if you include a test of cointegrating restrictions (which you do by imposing constraints with the append method), i don't see how you learn about whether a restriction was rejected or not!
I suppose that the eviews team forgot to supply this important information through a matrix, but still this won't be fixed anytime soon, can you indicate me a workaround how to grab the information I need from the cells of the output view?
