Imposition of zero lower boundary in endogenous variable
Posted: Wed Feb 04, 2009 6:52 am
by dino55
I'm wondering whether there is a easy way to establish a zero lower boundary in an endogenous model
variable, e.g. interest rates cannot go below zero?
I tried to work in the equation with the function @recode, but I always got an error message.
Thanks for any hints.
Re: Imposition of zero lower boundary in endogenous variable
Posted: Wed Feb 04, 2009 8:28 am
For some purposes you might try modeling log(y).
Posted: Tue Apr 14, 2009 7:14 am
by jlbrillet
You could add an equation creating a new variable x as :
x = y *(y>0)
and use x as the endogenous.
Take care,
Jean Louis Brillet.
Actually, the problem is when your model uses the logarithm of the variable. In this case it needs to be strictly positive, and probably different enough from zero (to avoid large derivatives). The problem lies with the "enough".
Posted: Tue Apr 14, 2009 7:30 am
x = y *(y>0)
Take care,
Jean Louis Brillet.
If you do this, you may need to think about estimation with a Tobit rather than a standard regression model.
Posted: Wed Apr 15, 2009 3:28 am
by jlbrillet
I thought you meant in a model identity. Of course if the equation was estimated the problem is different.
But if you want the variable to be positive it is probably that it should be so by nature (like the nominal interst rate, or GDP), which means it is positive on the sample period.
