problem with the command "pagesave" - Eviews 7
Posted: Fri Apr 29, 2011 7:53 am
by maragloria
Hi there,
I am having a bug with the command "pagesave2 on Eviews 7. I am trying to save some data from Eviews to an excel file.
Upon running the following lines:
%xlsfile = "X:\Equi_Val_Exc_G10\source_modeles_structurel.xlsx"
pagesave(t=excelxml) {%xlsfile} range="facmod" @keep sig_* @smpl 1990m01 @last
I get the following message:
EViews library error: 'Writing Excel (*.xlsx) files is currently not supported' in "PAGESAVE(T=EXCELXML) X:\EQUI_VAL_EXC_G10\SO ...
This is because my excel file is being deleted from its folder when the command is run. Why would that happen?
Thanks for your help,
Mara
Re: problem with the command "pagesave" - Eviews 7
Posted: Fri Apr 29, 2011 8:29 am
This isn't a bug. Rather it is exactly as the error message indicates - EViews will not save xlsx files.
Posted: Fri Apr 29, 2011 9:04 am
by maragloria
But why is the file being deleted when the code runs?
Posted: Fri Apr 29, 2011 9:36 am
by maragloria
I have another question about the command pagesave. I'm gonna post it in the forum related to programming.
Thanks in advance.
