File Paths and Include
Posted: Tue Apr 19, 2011 9:49 am
Working with Eviews 6 (July 2010 build).
A bit of setup:
I'm working with a group where we're all going to be working on individual parts of a program and then including the programs in a larger program. Each program that we'll be working on individually consists of 3 individual programs that run in sequence, but I've broken it up because you'll only need to run the first part once, but the other two parts will be run repeatedly. Since I'm working with Eviews 6, I've been using the include command plus the file path to pull the subsequent parts of the program - something like:
program 1
blah blah
include c:/test/program2.prg
program 2
blah blah
include c:/test/program3.prg
program 3
blah blah
I was trying to streamline this so that each person working won't have to change the file paths and then we won't all have to change the file paths back when we combine them by putting a change directory command at the start of program 1:
program 1
cd c:\test
blah blah
include program 2
program 2
blah blah
include program 3
program 3
blah blah
The problem:
The change directory command works (I can see it change in the lower right corner), but it continues to pull programs 2 and 3 from my directory when the file paths are not in the include commands rather than pulling them from my colleague's directories that the change directory command has switched it to. I tried running the program on one of their computers but because we have a shared networked drive that we're all working from, it continued to pull the programs from my files. I even tried screwing the included programs up on my colleague's drives to test which copy it was pulling from, but it still worked so I'm sure it was running off of my copy. I was wondering if there was some better way of running this or if this is an issue with the way Eviews pulls files. Let me know if the explanation of my problem doesn't make sense too.
-Thanks,
John
A bit of setup:
program 1
blah blah
program 2
blah blah
program 3
blah blah
program 1
cd c:\test
blah blah
include program 2
program 2
blah blah
include program 3
program 3
blah blah
The problem:
-Thanks,
John
