Output on Eviews changes
Posted: Thu Apr 14, 2011 2:52 am
when we put our data into eviews, one day we get a totally different result than another day.
Also, given a time series of +- 50 observations, a result appears. If we add the next observation (which does not deviate that much from the previous ones), again our results change drastically.
How is this possible? The time series are all the same and the estimation is also exactly the same.
How can we fix this problem?
We also noticed that when we estimate our equation, this gives an error, but when we afterwards give another equation by specifying the equation, get results and then use the first equation again (by specifying) the first equation works. Is there some kind of memory when you specify the equation?
We are using Eviews 7.
