fracdiff add-in
Posted: Tue Apr 05, 2011 7:59 am
by SnakeCharmerII
I recently download the fracdiff add-in and I've been receiving the following error message every time I've tried to run the add-in with a series Y,
"Y_DIFF_COEFFS is not defined."
Can anyone explain me the problem?
P.S.: I've also tried with the command window, changing the value of "d", changing the sample size, and with different options of the dialog. Nothing seems to work.
wfile.wf1
This is the series Y
(12.01 KiB) Downloaded 1221 times
Re: fracdiff add-in
Posted: Tue Apr 05, 2011 9:27 am
What degree of fractional differencing did you use? I just entered "1", and it worked for me.
Re: fracdiff add-in
Posted: Tue Apr 05, 2011 12:30 pm
by SnakeCharmerII
Hi Gareth,
I used a fractional differencing degree ("d") of 0.3 (I've also tried other fractional values of "d")
The value of d = 1 also work for me.
Thanks in advance.
Re: fracdiff add-in
Posted: Tue Apr 05, 2011 1:25 pm
Works for me with a value of 0.3 too. Is your copy of EViews up to date?
Re: fracdiff add-in
Posted: Tue Apr 05, 2011 1:32 pm
by SnakeCharmerII
Maybe thats the problem. I'm using a copy of eviews at work that seems to be not updated, Thanks anyway Gareth!
