Code for a smoothing Filter (Hodrick Prescot Filter)
Posted: Wed Mar 16, 2011 1:00 pm
Im trying to trace the explicit (model) code required to manually create a smoothed series (ideally HP Filter) from some raw (quarterly) data on GDP_c
I have a simple model (actually solved externally in WinSolve) that contains a smoothed GDP variable over the data period (produced using WinSolve’s own Hodrick-Prescott Table transformation on the raw GDP data)
But I then need to (dynamically) forecast this Hodrick-Prescott smoothing/filter series (or something similar) over a forecast period; so I need an explicit expression that I can code up in the model in order to produce such a HP smoothed forecast.
Is anyone aware of any "extracted" smoothing code in order to specify such an expression "manually" ( I realise Eviews
has internal "black box" routines to calculate such a smoothing transformation -but I need some explicit coding that I can use in WinSolve)
My simple example starting point is a modified MA(8) smoothing expression (with shift adjustment):
..but this does not replicate HP filter over the data period !!!
Most Kind
* GDPtr_c = ( +8/36*(GDP_c(-1)) +7/36*(GDP_c(-2)) +6/36*(GDP_c(-3) ) +5/36*(GDP_c(-4) )
+4/36*(GDP_c(-5)) +3/36*(GDP_c(-6)) +2/36*(GDP_c(-7) ) +1/36*(GDP_c(-8) ) /8 )
-0.25*( (GDPtr_c(-1)-GDP_c(-1))+(GDPtr_c(-2)-GDP_c(-2))+(GDPtr_c(-3)-GDP_c(-3))+(GDPtr_c(-4)-GDP_c(-4))
+(GDPtr_c(-5)-GDP_c(-5))+(GDPtr_c(-6)-GDP_c(-6))+(GDPtr_c(-7)-GDP_c(-7))+(GDPtr_c(-8)-GDP_c(-8)) ) ; ..but this does not replicate HP filter over the data period !!!
Most Kind
