Manual backwards stepwise routine
Posted: Fri Jan 23, 2009 9:19 am
'create some data - 20 X variables and a Y variable that depends upon X11-X15. 'X variables are put into a group called XS create u 1000 rndseed 1 group xs group g for !i=1 to 20 series x!i=nrnd %name="x"+@str(!i) xs.add {%name} g.add {%name} next series y = nrnd + 3 for !i=11 to 15 y = y + !i*x{!i} next 'perform backwards stepwise regression - first run a model with all Xs, then remove Xs one at a time based upon tstat. equation e1 !tstop=5 !stop=0 while !stop=0 e1.ls y c xs !mint=10000 !removedvar=0 for !i=1 to xs.@count !currentt = @abs(e1.@tstats(!i+1)) 'note plus one is since the equation has a constant as the first variable, but we are not testing the constant if !currentt < !mint then !mint = !currentt !removedvar=!i endif next if !mint>!tstop then !stop=1 else if !removedvar>0 then %removedvarname=xs.@seriesname(!removedvar) xs.drop {%removedvarname} endif endif wend show e1 'run an automatic stepwise and see if it matches equation e2.stepls(METHOD=UNI,BTOL=5,BACK,TSTAT) y c @ g show e2
Re: Manual backwards stepwise routine
Posted: Mon Nov 03, 2014 9:28 am
by lilian.ferro
Is it possible to include ARMA terms in this routine? I've tried to adapt your code, but it is not working.
Here is what I've tried to do:
group xs
xs.add ar(1) ma(1)
Tank you very much!
Posted: Mon Nov 03, 2014 9:36 am
You can't add AR or MA terms to a group, so, no, this method will not work at all.
