Group Object in a loop
Posted: Fri Jan 23, 2009 12:21 am
by adam_77
Dear all,
my problem is the following: I running regressions for 10 countries where the time series named as follows. Country_y, Country_X. Where y is the left side var and x the right side var, country is just the county name. What i want to do now is running a loop in which i´m regressing y on x and some leads and lags of the first difference of x for each country. For model selection a info. criterion is to be minimized. So far, i put the y´s and x´s into a group object and also i have a group object with the first differences of the x-series: grp_y, grp_x and dgrp_x
My code looks roughly as follows where i used different example-codes posted in that forum here (by the way, thanks for that!):
for !i=1 to 10
for %country=grp_y.@seriesname(!i)
equation eq_{%country}
!mininfocrit=??? ' i don´t know what to include here
for !lag=2 to 4
eq_{%counry}.ls grp_y(!i) c grp_x(!i) dgrp_x(!i) 'here i want to include leads and lags but the group index seems not to work with the leads and lags
if eq_{%country}.@aic<!mininfocrit then
!bestlag=!lag
!mininfocrit=eq_{%country}.@aic
endif
eq_{%country}.ls grp_y(!i) c grp_x(!i) dgrp{%country}(-1 to -!bestlag) dgrp{%country}(1 to !bestlag)
Although it might look confused, hope you somehow get my idea and are able to help me or you can point out a different way to do it. Thanks a lot in advance
Re: Group Object in a loop
Posted: Fri Jan 23, 2009 3:32 pm
by Gene
Here is what I would do... with USA, UK and JPN as the example countries, assuming you have USA_Y, USA_X, UK_Y, UK_X, etc. in your workfile. Notice I don't use the groups.
for %country USA UK JPN equation eq_{%country} !mininfocrit=999999 for !lag=-4 to -2 eq_{%country}.ls {%country}_y {%country}_x d({%country}_x)(-1 to !lag) if eq_{%country}.@aic<!mininfocrit then !bestlag=-!lag !mininfocrit=eq_{%country}.@aic endif Next eq_{%country}.ls {%country}_y {%country}_x d({%country}_x)(-1 to !bestlag) Next
You'll have to check out which of the below is the correct syntax:
d({%country}_x)(-1 to !lag) or d({%country}_x(-1 to !lag))
Posted: Sat Jan 24, 2009 2:06 am
by adam_77
Hi gene,
thanks for your help. I see what you mean and working with a group object is indeed somewhat cumbersome. But still, there is a error massage saying that ...-1 to -4 is not a valid index. Do you have any further ideas? I tried the syntax both ways
Cheers, Adam
Posted: Tue Jan 27, 2009 12:57 pm
by Gene
Hi gene,
Cheers, Adam
Then you'll have to build up the lag part of the equation. There are many ways to do this. One way is to build the equation specifcation string:
for %country USA UK JPN equation eq_{%country} !mininfocrit=999999 %eq_str = %country+"_y " + %country+"_x" %best_eq = %eq_str for !lag=1 to 4 %eq_str = %eq_str + " d("+ %country+"_x(-" + @str(!lag)+"))" eq_{%country}.ls {%eq_str} if eq_{%country}.@aic<!mininfocrit then %best_eq=%eq_str !mininfocrit=eq_{%country}.@aic endif Next eq_{%country}.ls {%best_eq} Next
Posted: Fri Mar 06, 2009 12:51 am
by calculus
Hi Gene,
worked out nice. And sorry, been abscent for a long time. Thanks a lot for your help
