Density Greater than 1.
Posted: Fri Feb 11, 2011 12:42 pm
by cpeter9
When I plot theoretical densities separated into different categories sometimes I get densities that reach to greater than 1 on the y-axis. Why is this?
I'm using EVIEWS 6.
Re: Density Greater than 1.
Posted: Fri Feb 11, 2011 12:48 pm
by cpeter9
The area under the curve sums to 1, but that doesn't necessarily mean that the peak won't be higher?
It seems this is the case according to this forum:
http://talkstats.com/showthread.php?t=12929
How would that be interpreted, though in terms of relative frequency?
Posted: Fri Feb 11, 2011 6:21 pm
Frequencies, in the way that I believe you are thinking about them, are only defined over regions for continuous random variables. Thus, you need to think about probabilities associated with a region (e.g., from 0 to .25 for a uniform(0, 1)) instead of countable points.
