Panel Logit
esperanza
Panel Logit
Postby esperanza » Fri Feb 04, 2011 8:09 am
Regards to every member of the forum,
I would be very grateful if someone advises me on how to run a panel logit with EViews5,
I am quite familiar with simple logit, but now I need to run a regression on a panel of six Asian countries in order to create an Early Warning System (EWS) for currency crises prediction. I have monthly data for about 5 years, all of the countries in the sample were actually in crises since 1997, July. As for explanatory variable X, I will take 12-month standart deviation of exchange rate and/or annual change in foreign exchange reserves. As for Y, I am slightly confused, probably merely Y=1 for all months during crisis years (1997-1999), Y=0 in all other cases will be assumed.
The difficulty is that I am confused on how to prepare the data, import and run a regression properly.
The purpose of the regression is similar to the one used by Lestano J. in the attached research paper.
Thank you for any useful help.
SSRN-id480021 (Lestano, Jan Jacobs).pdf
(188.51 KiB) Downloaded 759 times
esperanza
Re: Panel Logit
Postby esperanza » Sat Feb 05, 2011 9:56 am
please, have a look at the data attached, I am still confused in how to prepare/import it to EViews5,
this urgent, I have deadline next week...
thank you in advance.
data for panel logit.xls
(160.5 KiB) Downloaded 708 times
esperanza
Re: Panel Logit
Postby esperanza » Sun Feb 06, 2011 6:44 am
have anyone ideas on how to run logit on the panel of 7 countries for 1995:1m-2009:12m? in the file attached above?
Re: Panel Logit
Postby startz » Sun Feb 06, 2011 9:25 am
What happens when you read your data into EViews and use the logit command?
esperanza
Re: Panel Logit
Postby esperanza » Sun Feb 06, 2011 11:53 am
Startz, thank you for the reply! When I just try to open my series as an 'Equation', I recieve 'Alpha series in specification [var name] @EXPAND can convert to catagorical dummies' message. This happens in the very beginning so that I cannot even choose the type of regression to be run 'logit'.
Here is the file:
import data for panel logit-1.wf1
(96.99 KiB) Downloaded 686 times
Re: Panel Logit
Postby startz » Sun Feb 06, 2011 12:09 pm
Try just entering at the command line
logit y x1 x2 @expand(categoryVariable)
using your real variables of course.
esperanza
Re: Panel Logit
Postby esperanza » Sun Feb 06, 2011 12:14 pm
should it be as follows:
logit yindo x1indo @expand(x1indo)
it does not help, neither does: logit yindo x1indo @expand(categoryVariable), as you have suggested
Re: Panel Logit
Postby startz » Sun Feb 06, 2011 12:39 pm
You have two separate problems. The small one is that your variables are stored as alphas rather than as the usual numeric series. To get started, try
logit yindo c @val(x1indo)
The larger problem is that you probably want all your countries listed in one long variable with a separate variable indicating the country. One manual way to do this is to create a new undated workfile with 7 times 180 observations. Create a new variable x1 and copy and paste each country in order. Same thing for any other variables you have. Then create a new variable countryName that has a unique identifier for each country. All this will be a pain, but probably won't take more than an hour.
esperanza
Re: Panel Logit
Postby esperanza » Sun Feb 06, 2011 10:08 pm
Thank you, startz, for the constructive advice. As I have understood from your post, it is only possible to estimate logit for each separate country for time series data, but no panel logit is available? Another thing I wish to understand is what 'alphas' are. This is the first time I encounter this concept.
Re: Panel Logit
Postby startz » Mon Feb 07, 2011 8:05 am
No, you can do a panel logit. It's just not built into EViews as an automatic procedure so you're going to have to set it up manually.
esperanza
Re: Panel Logit
Postby esperanza » Mon Feb 07, 2011 9:08 am
Is it a long procedure to set it up manually? what should be done for it, could you please specify.
Re: Panel Logit
Postby startz » Mon Feb 07, 2011 9:21 am
esperanza
Re: Panel Logit
Postby esperanza » Tue Feb 08, 2011 5:01 am
startz, thank you. As I understood, I should place all countries in a row for each variable, so that I get single 'y' series and separate long time series for each x. now, I think everything is clear, thank you once again for your support, startz!
