Lagging independant variable in ARMA
jriskg
Postby jriskg » Thu Jan 27, 2011 11:07 am
Hi there
To be honest i'm new to eviews and am having issues in only this regard!
i have a very simple issue that i need clarity on please. I am having issues with putting in varying lagged independant variable into the ARMA regression code (i.e. x lagged once, x lagged twice, x laggred thrice, etc). Do i add in extra AR variables (i.e. AR(1); AR(2); AR(3); etc) and in doing so the independant variable is lagged, or do i run an ARMA (1,1) and actually lag the independant variable while keeping AR(1) and MA(1)???
Its a very simple regression, with one dependant variable and one independant variable.
Please help me on the code for the regression editor?!!!
Many thanks
Re: Lagging independant variable in ARMA
Postby EViews Gareth » Thu Jan 27, 2011 11:24 am
Do you want to include a lagged dependent variable, or an AR term? They are different when you have independent variables.
To include a lagged dependent variable, just have your equation like this:
Y C X Y(-1) Y(-2)
etc...
jriskg
Postby jriskg » Thu Jan 27, 2011 11:32 am
essentially i want to have a lagged independant term with the ARMA process.
So i simply do that? As opposed to including AR(1), AR(2), etc
Postby startz » Thu Jan 27, 2011 11:42 am
ls y c ar(1) ar(2) ma(1) x(-4)
jriskg
Postby jriskg » Thu Jan 27, 2011 11:57 am
I dont mean to sound silly but you confused me now.
If i'm running an ARMA (1,1) model and i want to lag the independant variable is the code:
Y C X(-1) X(-2) AR(1) MA(1)
or do i lag through AR in the sense:
Y C X AR(1) AR(2) MA(1)
Thank you for bearing with me
Postby startz » Thu Jan 27, 2011 12:02 pm
I missed the ARMA(1,1) point.
The AR and MA terms refer to how the lag of the residual is modelled. If you want to have an ARMA(1,1) with the current value of the independent variable X, write
ls y c x ar(1) ma(1)
If you want to use the first lag of X, instead write
ls y c x(-1) ar(1) ma(1)
jriskg
Postby jriskg » Thu Jan 27, 2011 12:11 pm
thank you so so much
