specifying redundant variables with GARCH
If you are doing least squares with a "magic" variable such as garch-in-mean on the right, is there a way to do the redundant variables test from the View menu? (Does the GARCH variable have a name?)
Re: specifying redundant variables with GARCH
You can't reference it, unfortunately. You'll have to run the test yourself manually (by doing the auxiliary regressions)
