program clash while running program
evs123
Postby evs123 » Wed Jan 05, 2011 4:45 am
I was running a program at home. At half way through, a Microsoft window error message pops up. It's really strange in that I ran the exactly the same program at office (running off Eviews 7.1 enterprise), and there was no problem. I don't understand why such error message would come up just because I was running Eviews 7.1 at home.
here are the window error messages (some usual words when program stops working)
"Eviews has stopped working
->check online for a solution
-> close the program"
Problem signature:
Problem Event Name: APPCRASH
Application Name: EViews7.exe
Application Version: 7.0.0.1
Application Timestamp: 4d1b80f4
Fault Module Name: StackHash_d885
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 4ab8f176
OS Version: 6.0.6001.2.1.0.768.2
Locale ID: 1033
Additional Information 1: d885
Additional Information 2: 369d09b6548578b3c53babf36b54ce04
Additional Information 3: 8ae0
Additional Information 4: 104a9351462ef616be31ba4cabf4164a
Can someone please help? Much appreciated.
Re: program clash while running program
Postby startz » Wed Jan 05, 2011 8:28 am
While not an explanation, have you updated EViews with the most recent updates?
evs123
Postby evs123 » Wed Jan 05, 2011 2:46 pm
Thanks Startz.
Yes, I updated Eviews frequently whenever patches are releases. In fact, I just updated my Eviews to 10 minutes ago, before that clash problem occurred.
I also tried inserting "stop" at different places in the program to track down which command was causing the problem. I found that Eviews stopped working (pop up that error message) at the last line below (generating residual series). If I have that stop command in between lines like below. Everything is fine, Eviews works through until that equation command line without problem. But if I take out that stop command, Eviews just clashed. It seems to me that the last line of generating residual series must be causing the problem.
equation eqLR1.ls lrentn=CLR1(1)+ CLR1(2)*lhp+ CLR1(3)*r
stop
eqLR1.makeresids ecta
Postby startz » Wed Jan 05, 2011 2:54 pm
What you're doing looks right to me...I guess an official answer is needed. If you can, post your workfile together with the program that dies for the EViews folks to look at.
Postby EViews Gareth » Wed Jan 05, 2011 2:58 pm
Exactly as Startz says - could you post the workfile and the program that causes the crash?
evs123
Postby evs123 » Tue Jan 11, 2011 2:04 am
Here are the codes which caused crash. As you can see, I have "stop" in between the last and 2nd last lines. In this case, the file works without crash. Once I remove "stop", the file just crashed. Help!!! :cry:
%path = @runpath cd %path close hp.wf1 'create file %HP_data="data.xls" %HP = "HP.wf1" %HP_data_PATH=%path+%HP_data %HP_PATH = %path + %HP %FDATA = "FDATA.WF1" %FDATA_PATH = "C:\DATA\"+ %FDATA wfopen %FDATA_PATH pagecopy(wf = %HP_PATH , smpl = @first @last) RNU_LFS GTM npop cons close %FDATA read(b3, s=INPUT, t=xls) %HP_data_PATH 15 sample ssall 1986Q2 2010Q3 sample ssfor 2003Q1 2010Q3 sample ssshock 2003Q2 2003Q2 smpl ssall series lrent=log(rent) series dlrent=100*(lrent-lrent(-1)) series lhp=log(hp) series dlhp=100*(lhp-lhp(-1)) series dlhp4=100*(lhp(+4)-lhp) series dlhp8=100*(lhp(+8)-lhp) series dlhp12=100*(lhp(+12)-lhp) series ddlhp=d(dlhp) series ly=log(gtm) series dly=(ly-ly(-1))*100 series lcpi=log(cpi) series lnpop=log(npop) series lgdi=log(gdi) series dlgdi=100*(lgdi-lgdi(-1)) series hpINDEX_R = 100*(hp/@elem(hp, "2004:4"))/(cpi/@elem(cpi, "2004:4")) hpINDEX_R.displayname Real house price index (2004 Dec Qtr =100) series hpINDEX_N = 100*hp/@elem(hp, "2004:4") hpINDEX_N.displayname Nominal house price index (2004 Dec Qtr =100) series lhpreal=log(hpINDEX_R) series dlhpreal=400*(lhpreal-lhpreal(-1)) 'calucate real gross rent, and compare it to nominal rent index (2004Q4 =100) series rentINDEX_R=100*(rent/@elem(rent, "2004:4"))/(cpi/@elem(cpi, "2004:4")) rentINDEX_R.displayname Real rent index (2004 Dec Qtr =100) series rentINDEX_N= 100*rent/@elem(rent, "2004:4") rentINDEX_N.displayname Nominal rent index (2004 Dec Qtr =100) 'Make some graphs graph chart1.line hpINDEX_R hpINDEX_N chart1.draw(line, left, rgb(0,0,127)) 100 graph chart2.line rentINDEX_R rentINDEX_N chart2.draw(line, left, rgb(0,0,127)) 100 graph chart3.line hpINDEX_N rentINDEX_N chart3.draw(line, left, rgb(0,0,127)) 100 graph chart4.line hpINDEX_R rentINDEX_R chart4.draw(line, left, rgb(0,0,127)) 100 graph chart_MERG1.merge chart1 chart2 chart3 chart4 show chart_MERG1.align(2,2,1) series rentn=52*rent*0.8 series lrentn=log(rentn) series dlrentn=(lrentn-lrentn(-1))*100 series dlrentn4=(lrentn(+4)-lrentn)*100 series dlrentn8=(lrentn(+8)-lrentn)*100 series dlrentn12=(lrentn(+12)-lrentn)*100 series g=3.5 series r=SVIR series dr=d(r) series ror=r-g series hpPV1=rentn/(ror/100) series rentyld=100*rentn/hp series drentyld=d(rentyld) graph chart5.line hp hpPV1 graph chart6.line rentyld ror graph chart_MERG2.merge chart5 chart6 show chart_MERG2.align(2,1,1) coef(50) CLR1 coef(50) CLR2 coef(50) CLR3 coef(50) CSR1a coef(50) CSR2a coef(50) CSR3a coef(50) CSR4a coef(50) CSR5a coef(50) CSR6a equation eqLR.ls lhp=CLR1(1)+ CLR1(2)*lrentn+ CLR1(3)*r 'cointegration relationship 1 (lrentn, lhp, r) stop eqlr.makeresids ecta
Postby EViews Gareth » Tue Jan 11, 2011 9:11 am
Could you post the accompanying data files?
