By-Group Stats
Posted: Wed Dec 29, 2010 10:38 am
by tchaithonov
Hey Guys, Happy Holidays!
I wonder if there is a way to create by-group stats (using @kurtsby as an example) for a bunch of variables in a panel model all at once (without looping (k+1) times) and write the results to a matrix/table (one value per variable per cross section) without creating another table/series/group? I just want to have a clean (n*t)*k matrix that I could further lookup on. If all of these are not possible, is there an easier way to just write the value of each cross section to a table/matrix than looping it t times to get the (n*(t-1))+1 value (that's just the 1st value of each cross section, n is max of cellid)? Please let me know. Thanks.
Tchaithonov
Re: By-Group Stats
Posted: Wed Dec 29, 2010 12:02 pm
If I'm understanding the question correctly (a big *if*, I know), what I'd probably do is to create a workfile with only the cross-section identifiers (or whatever the by-stat is for), then copy the group containing all of the series into the new page with the appropriate contraction. You can stom in the new page to get a matrix. Bring the matrix back and then delete the temporary page if desired.
P.S. - If the above doesn't correspond to your problem then I'm not following all of your dimensions (k is the variables, n is the number of cross-sections, t is time? -- if the latter, then why do we need to loop t times to get values?)
Re: By-Group Stats
Posted: Wed Dec 29, 2010 8:57 pm
by tchaithonov
yeah, you are right about the dimensions, I was wrong about the looping, it's n not t.
Re: By-Group Stats
Posted: Thu Dec 30, 2010 10:18 am
Is the suggested method going to work for you?
By the way, you can use pagecreate(id) to generate the new page...
Re: By-Group Stats
Posted: Fri Dec 31, 2010 8:31 pm
by tchaithonov
Hey Glenn,
Haven't tried .. but what I am doing is a variation of the rolling regression add-in. I am trying to calculate the stat of each variable per run and take out the variable(s) that do not have any variations (stdevsby and means give zeros, only kurtsby gives a NA) instead of having the regression run to an error. I don't know if pagecreat-ing the stats each time is efficient at all. But I will think about what you said and try it out before I plan the next step. Thanks tho.
Happy New Year!
Tchaithonov
