Model Proc Make Graph
donihue
Postby donihue » Mon Dec 27, 2010 12:03 pm
I am using Eviews 7.1, Dec 20 2010 build:
When attempting to create a graph containing deviations of actuals from active using the stochastic solution of a model created automatically by the excellent bvar add-in, the procedure fails with the message "xxx_2ACM is not defined" where "xxx" is alphabetically the first endogenous variable of the model. The same problem arises if the Proc "Make Group/Table" is selected.
I see no option to create this ACM variable in advance. Is this a bug, or an error on my part?
Workfile is attached.
Regards
Donihue
wogrom_var.wf1
(103.57 KiB) Downloaded 340 times
Re: Model Proc Make Graph
Postby EViews Gareth » Mon Dec 27, 2010 12:50 pm
I'll investigate.
