Out-of-sample forecast of multivariate GARCH Models
Posted: Wed Jan 14, 2009 2:35 am
by F_B
I'm writing a thesis about the Performence of Minimum Variance Hedge Ratios wich are determined by multivariate GARCH models. Therefore I would like to do conduct a 1-day/1-week ahead out-of-sample forecast of the conditional variance/covariance produces by the GARCH Model. I manage to generate the conditional variances of multivariate GARCH Models, e.g. the Constant conditional correlation model for a With-in-sample comperison through the standard "make covariance" function. I tried to create a model object from the estimated CCC Model in order to perform a out-of-sample forecast, but the model object as far es I know does not allow to extract the conditional covariances/variances into a seperate series (what I need to determine the hedge ratios). Does anyone know how to manage this task or has someone programmed a solution for my out of sample problem? I'm realy thankfull for answers as I'm have a timeproblem to finalise the thesis without a solution to this!
Thanks a lot in advance!!
Flo
Re: Out-of-sample forecast of multivariate GARCH Models
Posted: Wed Jan 14, 2009 2:09 pm
by trubador
I think it will be a better approach to produce a custom-made solution to your need, since you have a time constraint. I suggest you to share your workfile and provide more information on your model (e.g. variables, definitions, etc.), if it is OK for you. Right now I am very busy, but I will try to build a code for you as soon as I am available. Hence, I need to know your deadline on this issue. In the meantime, other members of the forum or moderators may also help you.
Posted: Mon Jul 26, 2010 7:41 am
by NTH_Le
Hi there,
I face the same problem as F_B. Here is my workfile and the information about the model I want to build. Could you give some help?
Many thanks.
Posted: Tue Jul 27, 2010 6:32 am
by trubador
The following inefficient yet effective piece of code should be doing what you want:
'First order model (BEKK-GARCH(1,1)) is assumed. sym(2) M vector(2) A1 vector(2) B1 'Create a system %sys = "sysbekk" system {%sys} {%sys}.append duks = c(1) {%sys}.append dukf = c(2) 'Estimate the system as diagonal BEKK smpl @first @first+368 {%sys}.arch @diagbekk c arch(1) garch(1) 'Save the conditional series {%sys}.makegarch 'Compute the in-sample hedge ratio series hr = garch_02/garch_01_02 delete garch* 'Rolling forecasts for !i=1 to 154 smpl @first @first+368+!i-1 {%sys}.arch @diagbekk c arch(1) garch(1) {%sys}.makegarch {%sys}.makeresids 'Generate new series for forecasted variables for %y GARCH_01 GARCH_02 GARCH_01_02 RESID01 RESID02 series {%y}f= {%y} next 'Organize the estimated coefficients into matrix form. 'Constant is assumed to be the only exogenous variable in each mean equation. 'Therefore coefficients of variance specification should start at c(3). M(1,1)={%sys}.@coefs(3) M(1,2)={%sys}.@coefs(4) M(2,2)={%sys}.@coefs(5) A1(1)={%sys}.@coefs(6) A1(2)={%sys}.@coefs(7) B1(1)={%sys}.@coefs(8) B1(2)={%sys}.@coefs(9) 'Number of observations used in the estimation !n={%sys}.@regobs 'Define out of sample forecast horizon !h = 1 'Perform dynamic forecasts via adjusting the sample (do not forget the missing value due to lag structure) for !j=1 to !h smpl @first+!n+!j @first+!n+!j+1 GARCH_01f = M(1,1) + A1(1)^2*RESID01f(-1)^2 + B1(1)^2*GARCH_01f(-1) GARCH_02f = M(2,2) + A1(2)^2*RESID02f(-1)^2 + B1(2)^2*GARCH_02f(-1) GARCH_01_02f= M(1,2) + A1(1)*A1(2)*RESID01f(-1)*RESID02f(-1) + B1(1)*B1(2)*GARCH_01_02f(-1) RESID01f = 0 RESID02f = 0 next 'Out-sample hedge ratios series hrf = garch_02f/garch_01_02f 'Combine in-sample and out-sample hedge ratios into one series hr = hrf delete garch* resid0* next smpl @all
Posted: Tue Jul 27, 2010 2:21 pm
by NTH_Le
Thank you so much Trubador. It really helps. :D
Posted: Thu Jun 09, 2011 7:40 am
by maxchen
neat idea!
However, if h>1, the code will not correct.
for example, let h=2, we should compute E_t(e_{t+1}^{2}) when producing conditional variance at t+2 conditional on time t.
