Table to TEX
EViews Esther
Table to TEX
Postby EViews Esther » Fri Dec 17, 2010 11:36 am
This thread is about the new version of tbl2tex add-in that converts a EViews table into LaTex-type table.
Please note that fancy styles (e.g. color/symbols/characters) and the line between header and content cannot be created.
However, we would like to actively continue working to better integrate LaTex in EViews.
[Change log]
  • 2011/02/10 Special characters (e.g. # & % $ ~ _ ^ { }) are controlled.
  • 2011/05/24 Additional special character \ (backslash) is controlled.
Last edited by EViews Esther on Thu Feb 10, 2011 11:45 am, edited 1 time in total.
tchaithonov
Re: Table to TEX
Postby tchaithonov » Mon Dec 20, 2010 9:20 am
Hi Esther,
I just took a look at your code and I wonder, since this is only for tables, wouldn't it be better if you make it into a table proc instead of a global one? Besides, it would require users to actually click on the table first before running the program (to get input for the _this command), maybe global is not the best idea. Just a thought.
Tchaithonov
Re: Table to TEX
Postby EViews Gareth » Mon Dec 20, 2010 9:50 am
Mistake in the installer. It actually works from _this, so yeah it should be a table proc. We'll update the installer.
EViews Esther
Re: Table to TEX
Postby EViews Esther » Mon Dec 20, 2010 10:03 am
The install program is updated.
maxchen
Re: Table to TEX
Postby maxchen » Wed Feb 09, 2011 7:18 pm
the "&" is not filtered!
for example
%ex7 = "\Example Files\EV7 Manual Data"
%ch28 = "\Chapter 28 - Quantile Regression"
%wf = @evpath + %ex7 +%ch28 +"\engel.wf1"
wfopen %wf
equation eq00.qreg y c x
freeze(tb0) eq00.output
tb0.tbl2tex(name="tb0",path="e:/")
in the tex file, the line
Huber Sandwich Standard Errors & Covariance
the character "&" should be changed to "\&"
EViews Esther
Re: Table to TEX
Postby EViews Esther » Thu Feb 10, 2011 9:44 am
Yes. You are right. Whenever we use one of the following special characters,
# & % $ ~ _ ^ { } \
we need to include a \ in front of the character.
Let me think about how to deal with these special characters.
dagfinnrime
Contact:
Re: Table to TEX
Postby dagfinnrime » Tue May 24, 2011 2:26 am
I think the following works.
Replace:
%special = "# & % $ ~ _ ^ { } \"
for !r=1 to !nrows
   for !c=1 to !ncols
      %temp = {%tbl}(!r,!c)
      for !i=1 to @wcount(%special)
         %cha = @word(%special,!i)
         if @wfind(%temp, %cha) then
            %cha1 = "\"+ %cha
            %temp = @replace(%temp, %cha, %cha1)
         endif
with:
%special = "# & % $ ~ _ ^ { }" '\"
for !r=1 to !nrows
   for !c=1 to !ncols
            %cha1 = "\"+ %cha
Change amounts to dropping "\" from list of special characthers and dropping the if-statement (which seems unnecessary). Maybe the @wfind, which should return position of character, doesn't work (Haven't checked).
About dropping "\". If the code encounters "\" then it would create "\\" which is a linebreak, which is not what you want. I'm not sure you really will use "\" that often that it is a big problem. If you want "\" in the list you have to add a special condition for that character (I think).
Dagfinn
EViews Esther
Re: Table to TEX
Postby EViews Esther » Tue May 24, 2011 8:48 am
dagfinnrime wrote:Change amounts to dropping "\" from list of special characthers and dropping the if-statement (which seems unnecessary). Maybe the @wfind, which should return position of character, doesn't work (Haven't checked).
Yes. @wfind should be replaced to @instr when we want to find the position of characters.
However, as you mentioned, the step to check whether special characters are found can be ignored.
dagfinnrime wrote:About dropping "\". If the code encounters "\" then it would create "\\" which is a linebreak, which is not what you want. I'm not sure you really will use "\" that often that it is a big problem. If you want "\" in the list you have to add a special condition for that character (I think).
We can keep the list for special characters by adding an additional condition - i.e. if %cha = "\" then - as follows.
%special = "# & % $ _ { } \ ~ ^"
for !r=1 to !nrows
   for !c=1 to !ncols
         if %cha = "\" then
            %temp = @replace(%temp, %cha, "$\backslash$")
         else
            %temp = @replace(%temp, %cha, "\" + %cha)
         endif
maxchen
Re: Table to TEX
Postby maxchen » Tue Aug 30, 2011 12:25 am
it seems that the download page http://www.eviews.com/Addins/addins.shtml has not been updated for this addin
Re: Table to TEX
Postby EViews Gareth » Tue Aug 30, 2011 7:49 am
What do you mean?
CharlieEVIEWS
Re: Table to TEX
Postby CharlieEVIEWS » Tue Sep 18, 2012 6:23 am
Perhaps I am doing something wrong here (using TeXWorks) but the compiled files look seriously disfigured - either when copied into a larger .tex or when run as the .tex produced directly by the add-in. Also, I am experiencing problems with the $\backslash$_ which occurs when you have an underscore in a variable name.
Any help? I am being a moron :roll: ? anyway, huge fan of the add-ins guys, keep up the great work.
tzink
Re: Table to TEX
Postby tzink » Fri Nov 02, 2012 2:03 pm
The output of this add-in doesn't compile for me. Errors are due to the fact that special characters aren't properly dealt with. For instance, the produced code snippet:
Equation: LN$\backslash$_S$\backslash$_P = P(1) + P(2)*LN$\backslash$_P$\backslash$_CU + P(3)*LN$\backslash$_P$\backslash$_FUEL + P(4) \\
results in the error:
! Missing $
The problem is that the underscores in my variables names are not filtered properly by the $\backslash$ command. I don't know enough about EViews programming to suggest a solution, unfortunately.
Has anyone on the dev team looked at GRETL's implementation? The Latex integration in GRETL is flawless, IMO.
CharlieEVIEWS
Re: Table to TEX
Postby CharlieEVIEWS » Sat Nov 16, 2013 9:50 am
Dear all,
Really looking forward to more LaTeX integration in EViews 9. However, I think there is a problem with the add-in. When I Proc --> add-in from a table object in EViews 8, Nov 13 2013 build, only the following is generated:
\documentclass[12pt]{article}
\begin{document}
\begin{table}
\centering
\begin{tabular}{}
\hline \hline
\hline \hline
\end{tabular}
\end{table}
\end{document}
Which doesn't generate any table... Does anybody have any suggestions or ideas? Warmest wishes as always, and again, thanks for all of your hard work on such a great product.
Charlie
basile
Re: Table to TEX
Postby basile » Sat Dec 14, 2013 10:22 am
Hello everyone,
I am a new user of eviews and I'm struggling to get tables in latex format... I downloaded the add in thing, but I have no idea how to generate table afterwards. So starting from a simple regression output window, can someone tell me how to get the latex table ?
Sorry for the stupid question :)
merry christmas everyone
Return to “Add-in Support”
Users browsing this forum: No registered users and 12 guests
