Reaching given targets with a compiled model (code included)
Posted: Wed Dec 15, 2010 5:11 am
Some time ago I presented a method which allows simulations to reach given targets for a set of endogenous variables , through the automatic computation of the same number of exogenous elements.
My post had very little success, which surprised me as I often met people who had trouble with this problem. Maybe I was not clear enough, I will rephrase the post.
One big advantage of this method is that it does not call for model redifinition. You can use the original compiled version. To switch to another instrument or target, you just have to change a name in one or two lines and run the program again.
To apply the method, what you have to do is give in a specific paragraph :
* The name of the model
* The sample period
* The list of the exogenized elements.
* The associated target values
* The list of exogenous instruments.
and include a specific generic program, good for any case.
The process can be repeated within the same simulation process. For instance, you might want to reach a large set of already available 2010 values, then make your 2011-2015 forecast reach a smaller set of targets.
This program is based on Newton's method. It works most of the time, provided the targets are reasonable and the instruments not too colinear. I use it in my work on various models and it saves me a lot of time.
It it does not work you can always go back to your usual technique. A friend of mine implemented the method in 15 minutes, without any help from me.
I include the program. What you just have to do is to replace the “solve” statement(s) in your main program by the following paragraph of EViews statements, in which you will include the requested information (see above).
At the end, this paragraph will “include” a generic EViews program (also provided) called “targetting” which must be available in your directory (do not make any changes).
I can also send you a paper describing the method.
Jean Louis Brillet.
THE PARAGRAPH
' START OF THE TARGETTING PROCESS
' Now we start creating the elements
' The starting and ending periods
' The name of the model
' The two lists of variables which change status
' The target values for the new exogenous
' They must be typed in the appropriate spaces
' in the lines showing : ***** User information ************
' No other editing is necessary
' We define the simulation periods
%date_1="starting date" ' ***** User information ************ Example : %date_1="2010Q3" (with quotes)
%date_2="ending date" ' ***** User information ************ Example : %date_2="2015Q4" (with quotes)
' We define the model name
%model= “model name1" ' ***** User information ************ Example : %model= “france_1" (with quotes)
' We define the lists of elements which change status
' exogenous to endogenous
' endogenous to exogenous
' The numbers must be the same
' If not, the program stops with a message
' For instance : f_crval : export/import ratio at current prices
' f_fcgp : budget deficit in GDP points
' f_unr : unemployment rate (0.xx)
' f_pfd : local demand deflator
' f_fdg : Government demand at constant prices
' f_scre : Social contributions rate for firms
' f_scrs : Social contributions rate for workers
' f_lg : Government employment
'***** User information ************ The list of new exogenous
group g_vexog1 list-of-instruments ' Example : group g_vexog1 f_fdg f_scre f_scrs f_lg (no quotes)
'***** User information ************ The list of targetted endogenous
group g_vendog1 list-of-instruments ' Example : group g_vendog1 f_crval f_fcgp f_unr f_pfd (no quotes)
'***** User information ************ The values of targetted endogenous
' For each target you must include a statement creating a “_star” variable. For instance
' genr f_crval_star=1 balanced trade balance
' genr f_fcgp_star=-3 3 points of GDP deficit
' genr f_unr_star=0.07 7% unemployment rate
' genr f_pfd_star=f_pfd*0.98 Deflator 2% lower than actual
' Finally, calling for the targetting algorithm
include targetting
' END OF THE TARGETTING PROCESS
Now the actual targetting program (NOT TO BE MODIFIED)
Just copy from the ***** line to the end of the message
Into a file called "targetting.prg"
' START OF The generic program for targetting
' It must be "included" after giving values to the requested parameters
' At the end of the process :
' The "actual" values of the endogenous will contain the solutions (the targets)
' The "actual" values of the endogenous will be set to the targetting values
' This means than a subsequent naked "solve" (no override or exclude, on the same period as the targetting process)
' will give the targets as a solution, in one iteration
' In case of problems, write to jlbrillet@yahoo.fr
' We copy the model into _model
copy {%model} _model
' We start with scenario "_z"
_model.scenario(n) "Scenario z"
_model.append assign @all _z
_model.solveopt(n=t m=10001 c=1e-8 o=g d=d)
' We define the sample range
if @isobject("_range") then
delete _range
endif
sample _range {%date_1} {%date_2}
smpl _range
' We solve the model once
_model.solve(n=t m=10002 c=1e-8 o=g d=d)
' We create a list of all the endogenous
_model.makegroup g_vendog @endog
' We set the "historical" values to the solution we obtained
for !i=1 to g_vendo.@count
%1=g_vendo.@seriesname(!i)
genr {%1}={%1}_z
tic ' Starting the stopwatch
' We delete Scenario 1 (it exists)
_model.scenario(d) "Scenario 1"
' We set the sample at the full range
smpl @first @last
genr _dum2=1
smpl _range
' We create a dummy variable for the full range
' anc compute the number of observations
if @isobject("_dum") then
delete _dum
endif
genr _dum=1
scalar _obsnb=@obssmpl
for !i=1 to g_vexog1.@count
vector(_obsnb) delv_{!i}
' nstar is the common number
scalar nstar=g_vexog1.@count
' The loop will run on all observations in the range
' The condition identifies the !iper th period in the sample
' for which a lag of !iper will produce an NA
' but not a lag of !iper+1
smpl @all
%1=g_vexog1.@seriesname(!i)
genr {%1}_0={%1}
genr {%1}_cur={%1}
' Srat of the loop on periods
for !iper=1 to _obsnb
smpl _range if _dum(-!iper)=na and _dum(-!iper+1)<>na
' We build Scenario 0 as the base
' It will contain the current solution
' The associated suffix will be "_0"
' We declare all the overriden exogenous
' (with the currently best solution)
' (note : we start with a blank list and fill it one by one)
_model.scenario(n) "Scenario 0"
_model.append assign @all _0
_model.override
_model.override(m) {%1}
' Now we create the alternate scenarios
' for computation of the Jacobian
' They are numbered 1 to nstar (here 2)
' The suffix is "_n"
' The exogenous are the same as Scenario 0
' Note : all exogenous have to be overriden
' but only one will change from the _0 value
' for a given scenario
for !i=1 to nstar
_model.scenario(n,a={!i},i="Scenario 0") Scenario {!i}
_model.append assign @all _{!i}
' Now we define the Jacobian
matrix(nstar,nstar) jacob
' print jacob
' Now we initialize the exogenous instruments
' used to reach the target
genr {%1}_cur={%1}
genr {%1}_0={%1}
for !j=1 to g_vexog1.@count
genr {%1}_{!j}={%1}
' And the endogenous target variables
for !i=1 to g_vendog1.@count
%1=g_vendog1.@seriesname(!i)
genr {%1}_0={%1}_z
genr {%1}_cur={%1}_0
' We set the maximum number of iterations
' and the convergence criterion
scalar nitmax=20
scalar sconv=1e-6
' We initialize as control variables
' the number of iterations
' And the variable controlling the convergence
!niter=0
!iconv=0
' We double the éléments so they can be displayed
scalar niter=0
scalar iconv=0
' We display several éléments for control
' print g_vexog1 g_vendog1
' print *_cur *_star
' Now we start the loop
' It will run while convergence is not achieved
' and the maximum numbre of loops is not reached
while !niter<=nitmax and !iconv=0
' We increment the iteration counter
!niter=!niter+1
scalar niter=niter+1
' We test for convergence
' We suppose it is achieved (!iconv=1)
' Then we look at the relative difference
' between the present solution and the target
' for each targetted endogenous
' If the relative difference is higher than the criterion
' for any target
' convergence is not yet reached (!iconv=0)
!iconv=1
scalar iconv=1
for !j=1 to g_vendog1.@count
%1=g_vendog1.@seriesname(!j)
genr dele_{!j}=({%1}_star-{%1}_cur)/({%1}_cur+({%1}_cur=0))
stom(dele_{!j},delv_{!j},_range)
if @abs(delv_{!j}({!iper}))>sconv then
!iconv=0
scalar iconv=0
endif
' We display the differences
' print dele_*
' We compute the base solution
' defined as Scenario 0
_model.scenario "Scenario 0"
solve(m=1003) _model
' The solution values are set as current
if niter=1 then
genr {%1}_base={%1}_0
endif
' We save the initial solution (for comparison with the shocked one later)
if niter=1 then
endif
' We display the current solution (exogenous + endogenous) and the targets
' print niter
' Now we compute the Jacobian
' We start a loop on the shocked instruments
' For each exogenous, we compute the whole set of overriding instruments
' shocking only the current one by 0.01 %
' while the others keep their base value
' This is necessary to implement the current changes
%2=g_vexog1.@seriesname(!j)
smpl @all
genr {%2}_{!i}={%2}_cur
genr {%2}_{!i}={%2}_cur*(1+.001*({!i}={!j}))
' We solve the model under Scenario !i
_model.scenario Scenario {!i}
solve(m=1004) _model
' Now we compute the relative change in the target endogenous
' This will give a column of the Jacobian matrix
%2=g_vendog1.@seriesname(!j)
genr _z=({%2}_{!i}-{%2}_cur)/({%2}_cur+({%2}_cur=0))/0.001
stom(_z,_zscal,_range)
jacob(!j,!i)=_zscal({!iper})
' This ends the computation of the Jacobian
' We compute its inverse
' print jacob
matrix jacob_inv=@inverse(jacob)
' print jacob_inv
' We apply to each exogenous a change equal to
' the inverse of the jacobian
' times the remaining error.
' This gives a new solution for the exogenous
' We start the process again until convergence (hopefully)
genr {%1}_old={%1}_cur
genr {%1}_cur={%1}_cur+{%1}_old*jacob_inv(!i,!j)*({%2}_star-{%2}_cur)/({%2}_cur+({%2}_cur=0))
genr {%1}_{!i}={%1}_cur
genr {%1}_0={%1}_cur
genr delxc_{%1}=({%1}_cur-{%1}_old)/{%1}_old
genr delxt_{%1}=({%1}_cur-{%1})/{%1}
' print delxc_*
' print delxt_*
wend
genr delf_{%1}=100*({%1}_0-{%1}_base)/({%1}_base+({%1}_base=0))
' we set the endogenous to the solution values
genr {%1}={%1}_0
for !i=0 to g_vendog1.@count
_model.scenario(d) Scenario !i
next ' end of the loop on periods
' We restore the full sample
smpl _range
genr {%1}={%1}_cur
toc ' Stopping the stopwatch. EViews displays the time the computation took
' End of targetting program
' The "actual" values of the endogenous contain the solutions (the targets)
' The "actual" values of the instruments are set to the targetting values
* The sample period
Jean Louis Brillet.
THE PARAGRAPH
include targetting
delete _range
endif
smpl _range
genr {%1}={%1}_z
smpl @first @last
genr _dum2=1
smpl _range
delete _dum
endif
genr _dum=1
smpl @all
genr {%1}_0={%1}
genr {%1}_cur={%1}
_model.override
for !i=1 to nstar
' print jacob
genr {%1}_cur={%1}
genr {%1}_0={%1}
genr {%1}_{!j}={%1}
genr {%1}_0={%1}_z
scalar nitmax=20
scalar sconv=1e-6
!niter=0
!iconv=0
scalar niter=0
scalar iconv=0
!niter=!niter+1
' for any target
!iconv=1
scalar iconv=1
!iconv=0
scalar iconv=0
endif
' print dele_*
if niter=1 then
endif
if niter=1 then
endif
' print niter
smpl @all
' print jacob
' print jacob_inv
' print delxc_*
' print delxt_*
wend
genr {%1}={%1}_0
smpl _range
genr {%1}={%1}_cur
