How to skip a regression when it has an error
Posted: Wed Dec 01, 2010 12:58 pm
by nesheus
Please see a segment of my program. In the regression equation, it cannot produce coefficients because it has a singular matrix. So tstat(1) gives "division by zero" error and stops the program.
I do this for many equations in a very long program. I need to detect this error and skip to calculate the t-statistics and continue to the other part of program but I cannot do it.
Is there any way of catching that regression didn't produce any estimation and skip it? I hope my explanation is clear. Thanks for your help.
equation eqalum1_12c.ls d(lalum) c ar(1) ma(1) ma(2) dum2 dum3 dum4 dum08Q4
if (@isna(eqalum1_12c.@tstat(1))=0) then
scalar p1_12c = @tdist(eqalum1_12c.@tstat(1), @regobs - eqalum1_12c.@ncoefs)
endif
Re: How to skip a regression when it has an error
Posted: Wed Dec 01, 2010 1:03 pm
You can use the @lasterrnum command to catch whether the previous line of a program caused an error or not. Thus something like:
if @lasterrnum=0 then
'no error caused stuff
else
'error caused stuff
endif
Posted: Wed Dec 01, 2010 1:08 pm
by nesheus
thanks. Are you sure the spelling is correct because I get this error when I used it
@lasterrnum is an illegal or reserved name
Posted: Wed Dec 01, 2010 1:12 pm
by nesheus
Actually, I should also point out that the regression line doesn't create any error. Only when i try to use the tstatistics I get an error (division by zero).
Posted: Wed Dec 01, 2010 1:14 pm
by nesheus
Also, I cannot find this function, @lasterrnum? Where do you go or how do you search? I don't think Eviews help is easy to find anything by simply typing.
Posted: Wed Dec 01, 2010 1:47 pm
Which version of EViews?
Posted: Wed Dec 01, 2010 1:51 pm
by nesheus
Eviews 6
Posted: Wed Dec 01, 2010 1:54 pm
by nesheus
Could you respond to my question on what to check without interrupting the program and skip this regression?
Posted: Wed Dec 01, 2010 2:09 pm
EViews 6 doesn't have @lasterrnum.
You can use @errorcount to check how many errors have occurred.
Posted: Wed Dec 01, 2010 2:17 pm
by nesheus
The regression does not have errors. Simply it doesn't converge. So when I try to calculate the t-statistics I get an error. Could you read my earlier messages. I should find a way of detecting that this regression did not do any estimation. I tried @coeff etc but could find a way. when i try t-statistics I get an error of division by zero.
Here is my regression result
WARNING: Singular covariance - coefficients are not unique
MA Backcast: OFF (Roots of MA process too large)
C 0.027287 NA NA NA
DUM2 -0.008653 NA NA NA
DUM3 -0.032919 NA NA NA
DUM4 0.013356 NA NA NA
DUM08Q4 -0.480224 NA NA NA
AR(1) -0.808295 NA NA NA
MA(1) 1.438928 NA NA NA
MA(2) 0.030255 NA NA NA
Posted: Wed Dec 01, 2010 2:20 pm
I read your message. Seems to me that you can just calculate the t-statistic and check whether that calculation caused an error or not.
Of course if you really want to test whether the t-statistic (standard error) is equal to an NA or not, you could just do that.
Posted: Wed Dec 01, 2010 2:22 pm
by nesheus
That is what I am doing here in the if statement
but I get an error message of division by zero and the program stops.
Posted: Wed Dec 01, 2010 2:29 pm
Without running your code it is really hard to know what you're doing wrong.
I've spent an hour giving you three different solutions to your potential problem.
