Maximum Number of Regressors in OLS
Posted: Mon Nov 29, 2010 1:15 am
by PERRYGOGAS
What is the maximum number of regressors I can use in EVIEWS? I need to estimate a model with 750 autoregressive lags.
Thank you very much!
Re: Maximum Number of Regressors in OLS
Posted: Mon Nov 29, 2010 1:25 am
by trubador
The default size of the coefficent vector (C) is 750. However, you can always define your own coefficent vector prior to the estimation and use it instead.
Posted: Mon Nov 29, 2010 8:41 am
by PERRYGOGAS
Hello and thank you! how do I specify the size?
I mean that ok I created a coefficient vector with 1000 rows named cc. But trying to estimate an OLS from Quick-Estimate Equation with 1000 regressors I still get an error message. How can I do it?
Posted: Mon Nov 29, 2010 9:06 am
Unfortunately you can no longer estimate an equation by list if you want to use your own coefficient vector. You have to estimate by expression.
Posted: Mon Nov 29, 2010 9:17 am
by PERRYGOGAS
Dear Gareth, thank you for your reply.
I have created a vector named "CC" as the alternative coef vector with 1000 rows.
Typing:
ls price c coal(-1 to 800)
I get an error message...how can I instruct eviews to use the CC coef vector and avoid this error message?
Posted: Mon Nov 29, 2010 9:25 am
As I said above, you can't specify by list (which is what you're doing there). You'll need to specify by expression:
price = cc(1) + cc(2)*coal(-1) + cc(3)*coal(-2) +
and so on. Yes this is a mighty pain if you have to write out 1000 of them.
However it isn't hard to write a program that will do it for you. See below:
create u 100000 series price = nrnd series coal = nrnd coef(1001) cc %regs = "" for !i=1 to 1000 %regs = %regs + " + cc(" + @str(!i) + ")*coal(-" + @str(!i) + ")" next equation e1.ls price=cc(1001) {%regs}
Posted: Mon Nov 29, 2010 10:03 am
by PERRYGOGAS
That is great! thank you very much!
Posted: Mon Nov 29, 2010 11:53 pm
by JamesEviews
Greetings. Gareth, plse unpack what the mini prog is doing. I am fascinated. In particular, the loop.
Regards, James Johnson
Posted: Tue Nov 30, 2010 12:07 am
The loop is just building up a string.
First iteration
%regs = "+ cc(1)*coal(-1)"
Second iteration
%regs = %regs + "+ cc(2)*coal(-2)"
which is
%regs = "+ cc(1)*coal(-1) + cc(2)*coal(-2)"
and so on.
At the end %regs will be equal to
"+ cc(1)*coal(-1) + cc(2)*coal(-2) + cc(3)*coal(-2) + ........ + cc(1000)*coal(-1000)"
I then just use that in the regression:
ls price=cc(1001) + cc(1)*coal(-1) + cc(2)*coal(-2) + cc(3)*coal(-3) + ...... + cc(1000)*coal(-1000)
Posted: Tue Nov 30, 2010 12:42 am
by JamesEviews
Much thanks, Gareth. You are a good teacher. Many thanks to Perry for asking the question also.
James
