An Example Trivariate GARCH-in-Mean Program for EViews 6.0
Posted: Wed Nov 24, 2010 1:48 am
by trubador
Please find attached a programming code for trivariate garch-in-mean model written for EViews 6.0 sometime ago. I see that there is a growing need on multivariate garch estimation in EViews 6.0 recently and therefore decided to post it. Please keep in mind that you have to change the relevant parts (sample, series name, etc.) of the code to suit your own needs. Hope it will be useful...
' TRIVARIATE GARCH-in-MEAN PROGRAM (01/05/2009) ' example program for EViews 6.0 LogL object ' ' restricted (diagonal) version of ' tri-variate BEKK of Engle and Kroner (1995): ' ' y = mu + lambda*H + res ' res ~ N(0,H) ' ' H = omega*omega' + beta*H(-1)*beta' + alpha*res(-1)*res(-1)'*alpha' ' ' where, ' y = 3 x 1 ' mu = 3 x 1 ' lambda = 3 x 1 ' H = 3 x 3 (symmetric) ' H(1,1) = variance of y1 (saved as var_y1) ' H(1,2) = cov of y1 and y2 (saved as cov_y1y2) ' H(1,3) = cov of y1 and y3 (saved as cov_y1y3) ' H(2,2) = variance of y2 (saved as var_y2) ' H(2,3) = cov of y2 and y3 (saved as cov_y2y3) ' H(3,3) = variance of y3 (saved as var_y3) ' omega = 3 x 3 (low triangular) ' beta = 3 x 3 (diagonal) ' alpha = 3 x 3 (diagonal) ' 'change path to program path %path = @runpath cd %path ' load workfile load intl_fin.wf1 ' dependent variables of all series must be continuous series y1 = dlog(sp500) series y2 = dlog(ftse) series y3 = dlog(nikkei) ' set sample ' first observation of s1 need to be one or two periods after ' the first observation of s0 sample s0 3/3/94 8/1/2000 sample s1 3/7/94 8/1/2000 ' initialization of parameters and starting values ' change below only to change the specification of model smpl s0 'get starting values from univariate GARCH-in-mean equation eq1.arch(archm=var,m=100,c=1e-5) y1 c equation eq2.arch(archm=var,m=100,c=1e-5) y2 c equation eq3.arch(archm=var,m=100,c=1e-5) y3 c 'save the conditional variances eq1.makegarch garch1 eq2.makegarch garch2 eq3.makegarch garch3 ' declare coef vectors to use in TVGARCHM model coef(3) lambda lambda(1) = eq1.c(1) lambda(2) = eq2.c(1) lambda(3) = eq3.c(1) coef(3) mu mu(1) = eq1.c(2) mu(2) = eq2.c(2) mu(3) = eq3.c(2) coef(6) omega omega(1) = (eq1.c(3))^.5 omega(2) = 0 omega(3) = 0 omega(4) = eq2.c(3)^.5 omega(5) = 0 omega(6) = eq3.c(3)^.5 coef(3) alpha alpha(1) = (eq1.c(4))^.5 alpha(2) = (eq2.c(4))^.5 alpha(3) = (eq3.c(4))^.5 coef(3) beta beta(1) = (eq1.c(5))^.5 beta(2) = (eq2.c(5))^.5 beta(3) = (eq3.c(5))^.5 ' use sample var-cov as starting value of variance-covariance matrix series cov_y1y2 = @cov(y1-mu(1)-lambda(1)*garch1, y2-mu(2)-lambda(2)*garch2) series cov_y1y3 = @cov(y1-mu(1)-lambda(1)*garch1, y3-mu(3)-lambda(3)*garch3) series cov_y2y3 = @cov(y2-mu(2)-lambda(2)*garch2, y3-mu(3)-lambda(3)*garch3) series var_y1 = @var(y1-lambda(1)*garch1) series var_y2 = @var(y2-lambda(2)*garch2) series var_y3 = @var(y3-lambda(3)*garch3) series sqres1 = (y1-mu(1)-lambda(1)*garch1)^2 series sqres2 = (y2-mu(2)-lambda(2)*garch2)^2 series sqres3 = (y3-mu(3)-lambda(3)*garch3)^2 series res1res2 = (y1-mu(1)-lambda(1)*garch1)*(y2-mu(2)-lambda(2)*garch2) series res1res3 = (y1-mu(1)-lambda(1)*garch1)*(y3-mu(3)-lambda(3)*garch3) series res2res3 = (y2-mu(2)-lambda(2)*garch2)*(y3-mu(3)-lambda(3)*garch3) ' constant adjustment for log likelihood !mlog2pi = 3*log(2*@acos(-1)) ' ........................................................... ' LOG LIKELIHOOD ' set up the likelihood ' 1) open a new blank likelihood object name tvgarch ' 2) specify the log likelihood model by append ' ........................................................... logl tvgarchm ' squared errors and cross errors tvgarchm.append @logl logl tvgarchm.append sqres1 = (y1-mu(1)-lambda(1)*var_y1)^2 tvgarchm.append sqres2 = (y2-mu(2)-lambda(2)*var_y2)^2 tvgarchm.append sqres3 = (y3-mu(3)-lambda(3)*var_y3)^2 tvgarchm.append res1res2 = (y1-mu(1)-lambda(1)*var_y1)*(y2-mu(2)-lambda(2)*var_y2) tvgarchm.append res1res3 = (y1-mu(1)-lambda(1)*var_y1)*(y3-mu(3)-lambda(3)*var_y3) tvgarchm.append res2res3 = (y2-mu(2)-lambda(2)*var_y2)*(y3-mu(3)-lambda(3)*var_y3) ' variance and covariance series tvgarchm.append var_y1 = omega(1)^2 + beta(1)^2*var_y1(-1) + alpha(1)^2*sqres1(-1) tvgarchm.append var_y2 = omega(2)^2+omega(4)^2 + beta(2)^2*var_y2(-1) + alpha(2)^2*sqres2(-1) tvgarchm.append var_y3 = omega(3)^2+omega(5)^2+omega(6)^2 + beta(3)^2*var_y3(-1) + alpha(3)^2*sqres3(-1) tvgarchm.append cov_y1y2 = omega(1)*omega(2) + beta(2)*beta(1)*cov_y1y2(-1) + alpha(2)*alpha(1)*res1res2(-1) tvgarchm.append cov_y1y3 = omega(1)*omega(3) + beta(3)*beta(1)*cov_y1y3(-1) + alpha(3)*alpha(1)*res1res3(-1) tvgarchm.append cov_y2y3 = omega(2)*omega(3) + omega(4)*omega(5) + beta(3)*beta(2)*cov_y2y3(-1) + alpha(3)*alpha(2)*res2res3(-1) ' determinant of the variance-covariance matrix tvgarchm.append deth = var_y1*var_y2*var_y3 - var_y1*cov_y2y3^2-cov_y1y2^2*var_y3+2*cov_y1y2*cov_y2y3*cov_y1y3-cov_y1y3^2*var_y2 ' calculate the elements of the inverse of var_cov (H) matrix ' numbered as vech(inv(H)) tvgarchm.append invh1 = (var_y2*var_y3-cov_y2y3^2)/deth tvgarchm.append invh2 = -(cov_y1y2*var_y3-cov_y1y3*cov_y2y3)/deth tvgarchm.append invh3 = (cov_y1y2*cov_y2y3-cov_y1y3*var_y2)/deth tvgarchm.append invh4 = (var_y1*var_y3-cov_y1y3^2)/deth tvgarchm.append invh5 = -(var_y1*cov_y2y3-cov_y1y2*cov_y1y3)/deth tvgarchm.append invh6 = (var_y1*var_y2-cov_y1y2^2)/deth ' log-likelihood series tvgarchm.append logl = -0.5*(!mlog2pi + (invh1*sqres1+invh4*sqres2+invh6*sqres3 +2*invh2*res1res2 +2*invh3*res1res3+2*invh5*res2res3 ) + log(deth)) ' remove some of the intermediary series tvgarchm.append @temp invh1 invh2 invh3 invh4 invh5 invh6 sqres1 sqres2 sqres3 res1res2 res1res3 res2res3 deth ' estimate the model smpl s1 tvgarchm.ml(showopts, m=100, c=1e-5) ' change below to display different output show tvgarchm.output graph var.line var_y1 var_y2 var_y3 graph cov.line cov_y1y2 cov_y1y3 cov_y2y3 show var show cov ' LR statistic for univariate vs trivariate scalar lr = -2*(eq1.@logl + eq2.@logl + eq3.@logl - tvgarchm.@logl) scalar lr_pval = 1 - @cchisq(lr,3)
Re: An Example Trivariate GARCH-in-Mean Program for EViews 6
Posted: Wed Nov 23, 2011 1:06 pm
by maryamjannesari
hi
i entered all the code in logl window,but i got error message that no equation in system or model,can u help me ?
Posted: Wed Nov 23, 2011 1:10 pm
The code Trubador posted is an EViews program. You should copy it into a Program (File->New->Program)
Posted: Fri Nov 25, 2011 8:50 am
by maryamjannesari
ok,thanks ,but when i copy them in the program window ,i got the error message about my path that not found on disk ,can u plz help me
Posted: Fri Nov 25, 2011 10:15 am
by maryamjannesari
thank u ,thank u thank u ,i solve it
Posted: Tue Nov 29, 2011 11:47 pm
by JackCrow
Just to be clear, this model contains only a mean and own-variance effect in the mean equation, right?
In other words, y1=c+lambda1*garch1+res1. Can this code be altered to estimate less parsimonious models?
I need to estimate y1=c+lambda1*garch1+psi1*garch2+rho1*garch3+res1, y2 and y3 similar. Can you simply create conditional variance estimates, add necessary coefficients (with starting values for psi and rho gained from rerunning the univariate garch-m model with the conditional variance from the other equations) and then just change the residual and variance/covariance equations and estimate that model with this code?
Help is greatly appreciated.
Posted: Sat Aug 02, 2014 12:27 pm
by wuyunting
Hello, does anyone else know how to change the code about the matrix determinant and inverse matrices into a 7 by 7 matrix instead of 3 by 3? I try to calculate the determinant by eviews and create a series for that number(of the determinant), and I use the same method for inverse matrices.
matrix (7,7) m2
m2.fill var_y1, cov_y1y2, cov_y1y3, cov_y1y4, cov_y1y5 ,cov_y1y6 ,cov_y1y7, cov_y1y2, var_y2, cov_y2y3 ,cov_y2y4, cov_y2y5 ,cov_y2y6, cov_y2y7 ,cov_y1y3, cov_y2y3, var_y3 ,cov_y3y4 ,cov_y3y5, cov_y3y6, cov_y3y7, cov_y1y4 ,cov_y2y4, cov_y3y4, var_y4, cov_y4y5, cov_y4y6, cov_y4y7, cov_y1y5 ,cov_y2y5, cov_y3y5, cov_y4y5, var_y5, cov_y5y6, cov_y5y7, cov_y1y6 ,cov_y2y6, cov_y3y6, cov_y4y6, cov_y5y6, var_y6, cov_y6y7 ,cov_y1y7, cov_y2y7, cov_y3y7, cov_y4y7, cov_y5y7, cov_y6y7 ,var_y7
scalar dm2=@det(m2)
series sdm2=dm2
tvgarchm.append deth=sdm2
however, the outcome for the model with code 'tvgarchm.ml(showopts, m=100, c=1e-5) show tvgarchm.output graph cov.line cov_y1y2 cov_y1y3 cov_y1y4 cov_y1y5 cov_y1y6 cov_y1y7' is several outlier points and a straight line. I cannot do manually since it involves huge calculation. Thank you!
Posted: Sat Mar 07, 2015 4:51 am
by thaotc4ueh
I also have a question like you, what did you do?
Re: An Example Trivariate GARCH-in-Mean Program for EViews 6.0
Posted: Wed Aug 11, 2021 8:59 am
by Khalid Ul Islam
Hello sir, I have used the program that you have posted to run GARCH BEKK in Eviews 10, however when i estimate the system i get the error message "!MLOG2PI is not defined in "LOGL = -0.5*(!MLOG2PI +(INVH1*SQRES1+INVH4*SQRES2+INVH6*SQRES3+2*INVH2*RES1RES"
Kindly help me
Posted: Wed Aug 11, 2021 9:06 am
by Khalid Ul Islam
Hello sir, I have used the program that you have posted to run GARCH BEKK in Eviews 9, however when i estimate the system i get the error message "!MLOG2PI is not defined in "LOGL = -0.5*(!MLOG2PI +(INVH1*SQRES1+INVH4*SQRES2+INVH6*SQRES3+2*INVH2*RES1RES"
Kindly help me
