Consumption based asset pricing models
Posted: Tue Nov 23, 2010 6:18 pm
I'm doing my dissertation on empirically comparing asset pricing models through GMM, I'm having a bit of trouble estimating and testing the models.
I'm comparing the standard expected utility model with constant relative risk aversion, a recursive utility model (Epstien & Zin), two habit persistence models: internal habit persistence (Ferson & Constantinides) and an external habit model (Campbell and Cochrane). The topic is relatively new to me but I've read up on the theory and papers that compare the models but now I have to compare them for my self with my dataset on eviews and none of the papers I've seen use Eviews. these are my problems:
I've set up a system with the moment conditions, on the estimation options I choose Time series HAC,I think I use 2SLS? from what i've understood I need to estimate with the identity matrix first then the matrix updates to the "optimal" weighting matrix ( as described by hansen and singleton) the inverse of the variance- covariance matrix of the sample counter part of the pricing equation E(m R)-1=0, m= stochastic discount factor for a model, R= returns of assets.
I want to use the optimal matrix as above but also get results with just the identity matrix for comparison purposes, what settings do I choose in Eviews to conduct it both ways?
I'm a bit confused about the kernel and bandwith options, none of the papers I've looked at say anything about this.
I also want to conduct Hansen and Jagannathans Volatility bounds and Specification error tests as non parametric evaluations. If anyone's familiar with this, how can I do it on eviews?
Volatility bounds : Std(m)>Std(x)= {[E(q)-E(m)E(x)]' *(unconditional variance covariance matrix of x)^-1[E(q)-E(m)E(x)]}^(1/2)
E(m)= unconditional mean of candidate stochastic factor Std(m)= standard deviation of candidate stochastic discount factor, x= pay off vector, p= asset price vector
Specification error tests: d= {[E(q)-E(mx)]' E(xx')^-1[E(q)-E(mx)]}^(1/2), E(xx')^-1 which is fixed is supposed to be a weighting matrix but by using the pre fixing the matrix to that for comparison
umm in the internal habit model, the SDF has expectations operators in it, how do I define that in the system? for exapmple the numerator in the SDF function is
(Ct+1-bCt)^-y - bFEt+1(Ct+2-bCt+1)^-y the t's and t+1's are supposed to be subscripts, the denominator is the same but lagged vales of c. Do I just type it out as though they arent there? is there an Expectations operator command in eviews?
let me give you an idea of what my problem is exactly, the topic was suggested by a lecturer, the topic isnt covered in our curriculum but it appealed to me cause it was a straight forward comparison that was just demanding technically (which i don't mind) compared to the other topics. but my supervisor hasn't replied to any of my emails or anything. So I've had to learn this on my own from the articles on each model and what ever papers that go into the topic (I've found that there so many different takes on how people estimate them, most of them do it through GMM but even in that they take different approaches from how they set different restrictions or additional conditions to different techniques in GMM) , I've wasted alot of time getting confused reading papers which I now realise are out of bounds for my disso, In fact all I have are other peoples studies and articles to base what my disso should be structured as. I think I have a decent grasp of the models now and an alright idea of techniques I'm supposed to use but on actually doing the empirical work on eviews i'm screwed, this method is totally new to me. If anyone could guide me on a framework with in Eviews It would save my life, literally. I can upload a doc breifly explaining each model and the non parametric evaluations if someone isn't familiar with topic but would still like to help......
oh one last thing, after I get estimates for the coefficients ,run the estimations will different pre specified values and instrument sets, compare jstats.... etc. The most basic thing: how do I graph the fitted results with the actual asset data.
Thanks in advance
Thanks in advance
