%ex7 = "\Example Files\EV7 Manual Data"
%ch26 = "\Chapter 26 - Discrete and Limited Dependent Variable Models"
%wf = @evpath + %ex7 +%ch26 +"\order.wf1"
wfopen %wf
equation eq01.ordered danger body brain sleep
c = 0
equation eq02.ordered(showopts) danger body brain sleep
c = 0
equation eq03.ordered(showopts) danger = c(1)*body + c(2)*brain + c(3)*sleep 'by expression
freeze(gfr) eq02.resids
1 eq03 usese the current values in C as starting values, furthermore, the output does not report the limit
points
2 in graph gfr, the fitted value seems to be residuals+actual value, it seems no meaning
what's more, by point and click, select eq02, View -> Generalize residual graph, then the legend of the graph reads "standardized residual" not "generalized residual" (it is fine with V5.1)
one last concern, Eq26.23 on user manual, the gamma_{y_{i+1}} should be gamma_{y_{i}+1}. Note that y_{i+1} is not equal to y_{i}+1
