syntax "group" misbehaviour
Posted: Sun Nov 21, 2010 6:16 am
by nupogodi
I have only one time series in my workbook, the time series is called "myseries".
The following syntax...
group mygroup myseries w*
.. returns an error message ("W is not defined") but it should not, because "myseries" is actually present in the workbook.
In addition, the syntax...
group mygroup w*
...should create an empty group but not to prompt the error message
can you fix this?
Re: syntax "group" misbehaviour
Posted: Mon Nov 22, 2010 10:09 am
This isn't a bug per se, rather it is designed behaviour. The group is supposed to error if no match was found.
Part of this arises from the dual use of the * character as a wildcard and as a multiplication. If you type
group mygrp x*y
EViews will first check whether there is a series called X and a series called Y, and will then multiply them and put the result in the group. If there is no X and no Y, then it will do a pattern search for any series called X*Y where * is a wildcard.
If both fail, then EViews doesn't know what you were intending to do. Whilst it may be better for the group to return empty if you were really trying to do a pattern match, it is certainly not good for an empty group to be returned if you were trying to do the multiplication.
You can use the @wlookup function do get the behaviour you do want though:
%temp = @wlookup("w*", "series") group mygroup myseries {%temp}
