x12-arima version 3.0
francisco
Postby francisco » Thu Nov 18, 2010 10:45 am
Please could update the x-12-ARIMA seasonal adjustment (both the menu as the command x12a) to be compatible with version 0.3.
Thanks,
Francisco
Re: x12-arima version 3.0
Postby EViews Jason » Thu Nov 18, 2010 11:03 am
Not clear what you are asking for here.
If you are asking that version 0.3 to be shipped with EViews as opposed to the current 0.2.9, please see http://forums.eviews.com/viewtopic.php? ... rima#p7976
If you are reporting an incompatibility issue after inserting 0.3 in place of 0.2.9, please specify exactly what you are doing and why you believe there is an incompatibility.
francisco
Postby francisco » Thu Nov 18, 2010 11:14 am
I followed your recommendation to upgrade to version 0.3 changing the x12a.exe program, however, when I run the x-12-arima from the menu seasonally adjusted mark error. The problem is that the new version has a new spec pickmdl and other modifications, which apparently has compatibility problems with the option of reading a model from the file x12.mdl in the version 0.2.9.
Thanks again!
Francisco
Postby EViews Jason » Thu Nov 18, 2010 1:29 pm
x12a.mdl was once part of the x12 distribution. It appears as though it is no longer. You may want to contact the US Census Bureau directly for more information.
