Error while estimating bv GARCH
Posted: Thu Nov 18, 2010 5:24 am
Dear Eviews forum operators,
While estimating an bivariate GARCH in Eviews 6 I run into the following error:
"Insufficient number of observations"
This occurs when the program is in line "equation eq1.arch....". I think the problem is in the starting values the program defines, but I don´t completely understand how I can fix this. What does the "m=100" and "c=1 e-5" mean? I already tried to shift around with the sample size, but this did not fix it. My data are two series containing residuals of a VEC model I estimated earlier on two series containing daily closing prices for 2006 and 2008 of a stock.
Could you please help me out? Do I simply have too few obserrvations?
Thanks and kind regards!
The Eviews bivariate GARCH program I already adjusted a little (so please ignor my adjustments) looks like:
' BV_GARCH.PRG (3/30/2004)
' Revised for 6.0 (3/7/2007)
' example program for EViews LogL object
' restricted version of
' bi-variate BEKK of Engle and Kroner (1995):
' y = mu + res -> y = mu + H*lambda + res
' res ~ N(0,H) (YK: So H is the variance-covariance that will be modelled, Brooks page 509 first few lines of text)
' (YK But H is used twice! In the residual and with lambda, what is lambda?)
' H = omega*omega' + beta H(-1) beta' + alpha res(-1) res(-1)' alpha' (YK: Brooks page 509, BEKK model)
' where
' y = 2 x 1 (YK: the variables/series)
' mu = 2 x 1 (YK: Wat is this?)
' -> lambda = 2 x 1
' H = 2 x 2 (symmetric)
' H(1,1) = variance of y1 (saved as var_y1)
' H(1,2) = cov of y1 and y2 (saved as var_y2)
' H(2,2) = variance of y2 (saved as cov_y1y2)
' omega = 2 x 2 low triangular
' beta = 2 x 2 diagonal (YK: Brooks page 509, "A")
' alpha = 2 x 2 diagonal (YK: Brooks page 509, "B")
'change path to program path
'%path = @runpath
'cd %path
' load workfile
'load intl_fin.wf1
'select right page
pageselect Closing_bids
'YK: delete all NAs from series by making them 0
series resid_nyse_ret_2=@recode(resid_nyse_ret=NA,0,resid_nyse_ret)
series resid_nonnyse_ret_2=@recode(resid_nonnyse_ret=NA,0,resid_nonnyse_ret)
'YK: make all resids positive (not necessary)
'series resid_nyse_ret_3=@abs(resid_nyse_ret_2)
'series resid_nonnyse_ret_3=@abs(resid_nonnyse_ret_2)
' dependent variables of both series must be continues
smpl @all
series y1 = resid_nyse_ret_2 'YK: removed dlog as data are already on squared return
series y2 = resid_nonnyse_ret_2 'YK: removed dlog as data are already on squared return
' set sample
' first observation of s1 need to be one or two periods after
' the first observation of s0
sample s0 3/22/2006 11/17/2008
sample s1 3/24/2006 11/17/2008
' initialization of parameters and starting values
' change below only to change the specification of model
smpl s0
'get starting values from univariate GARCH
'equation eq1.arch(m=100,c=1e-5) y1 c
'equation eq2.arch(m=100,c=1e-5) y2 c
equation eq1.arch(archm=var,m=100,c=1e-5) y1 c '(YK: Set the number of observations???)
equation eq2.arch(archm=var,m=100,c=1e-5) y2 c
'save the conditional variances
eq1.makegarch garch1
eq2.makegarch garch2
' declare coef vectors to use in bi-variate GARCH model
' see above for details
'coef(2) mu
' mu(1) = eq1.c(1)
' mu(2)= eq2.c(1)
'coef(3) omega
' omega(1)=(eq1.c(2))^.5
' omega(2)=0
' omega(3)=eq2.c(2)^.5
'coef(2) alpha
' alpha(1) = (eq1.c(3))^.5
' alpha(2) = (eq2.c(3))^.5
'coef(2) beta
' beta(1)= (eq1.c(4))^.5
' beta(2)= (eq2.c(4))^.5
'new values
' declare coef vectors to use in GARCH model
coef(2) lambda
lambda(1) = eq1.c(1)
lambda(2) = eq2.c(1)
coef(2) mu
mu(1) = eq1.c(2)
mu(2)= eq2.c(2)
coef(3) omega
omega(1)=(eq1.c(3))^.5
omega(2)=0
omega(3)=eq2.c(3)^.5
coef(2) alpha
alpha(1) = (eq1.c(4))^.5
alpha(2) = (eq2.c(4))^.5
coef(2) beta
beta(1)= (eq1.c(5))^.5
beta(2)= (eq2.c(5))^.5
' constant adjustment for log likelihood
!mlog2pi = 2*log(2*@acos(-1))
'old values
' use var-cov of sample in "s1" as starting value of variance-covariance matrix
'series cov_y1y2 = @cov(y1-mu(1), y2-mu(2))
'series var_y1 = @var(y1)
'series var_y2 = @var(y2)
'series sqres1 = (y1-mu(1))^2
'series sqres2 = (y2-mu(2))^2
'series res1res2 = (y1-mu(1))*(y2-mu(2))
series cov_y1y2 = @cov(y1-mu(1)-lambda(1)*garch1, y2-mu(2)-lambda(2)*garch2)
series var_y1 = @var(y1-lambda(1)*garch1)
series var_y2 = @var(y2-lambda(2)*garch2)
series sqres1 = (y1-mu(1)-lambda(1)*garch1)^2
series sqres2 = (y2-mu(2)-lambda(2)*garch2)^2
series res1res2 = (y1-mu(1)-lambda(1)*garch1)*(y2-mu(2)-lambda(2)*garch2)
' LOG LIKELIHOOD
' set up the likelihood
' 1) open a new blank likelihood object (L.O.) name bvgarch
' 2) specify the log likelihood model by append (YK: "Append" means "to add")
logl bvgarch
'old values
'bvgarch.append @logl logl
'bvgarch.append sqres1 = (y1-mu(1))^2
'bvgarch.append sqres2 = (y2-mu(2))^2
'bvgarch.append res1res2 = (y1-mu(1))*(y2-mu(2))
' squared errors and cross errors
bvgarch.append sqres1 = (y1-mu(1)-lambda(1)*garch1)^2
bvgarch.append sqres2 = (y2-mu(2)-lambda(2)*garch2)^2
bvgarch.append res1res2 = (y1-mu(1)-lambda(1)*garch1)*(y2-mu(2)-lambda(2)*garch2)
' calculate the variance and covariance series
bvgarch.append var_y1 = omega(1)^2 + beta(1)^2*var_y1(-1) + alpha(1)^2*sqres1(-1)
bvgarch.append var_y2 = omega(3)^2+omega(2)^2 + beta(2)^2*var_y2(-1) + alpha(2)^2*sqres2(-1)
bvgarch.append cov_y1y2 = omega(1)*omega(2) + beta(2)*beta(1)*cov_y1y2(-1) + alpha(2)*alpha(1)*res1res2(-1)
' determinant of the variance-covariance matrix
bvgarch.append deth = var_y1*var_y2 - cov_y1y2^2
' inverse elements of the variance-covariance matrix
bvgarch.append invh1 = var_y2/deth
bvgarch.append invh3 = var_y1/deth
bvgarch.append invh2 = -cov_y1y2/deth
' log-likelihood series
bvgarch.append logl =-0.5*(!mlog2pi + (invh1*sqres1+2*invh2*res1res2+invh3*sqres2) + log(deth))
' remove some of the intermediary series
' bvgarch.append @temp invh1 invh2 invh3 sqres1 sqres2 res1res2 deth
' estimate the model
smpl s1
bvgarch.ml(showopts, m=100, c=1e-5)
' change below to display different output
show bvgarch.output
graph varcov.line var_y1 var_y2 cov_y1y2
