Setting sample size
Posted: Fri Jan 09, 2009 3:32 am
by fraN
hi,
I am using Eview6 version and i have a sample with 2371 observation. I should create two sub-samples by using the following commands (I do not know in whic version of Eviews those commands were written):
sample s1 %first+1 %last
sample s2 %first+!q %last
So in the window command, I wrote:
sample s1 1+1 2371
...and the sample was created, then I wrote:
sample s2 1+!3 2371
after entering that command I got the following warning from Eviews "Error in Sample: !3 is not defined".
I was wondering what is the probelm and if I can get the same result by writing just 6 rather than !3 (..but i am not confident by using this last solution that is 6 rather than !3). May anyone give me any indication, please?
francesco
Re: Setting sample size
Posted: Fri Jan 09, 2009 6:07 am
by startz
hi,
sample s1 1+1 2371
sample s2 1+!3 2371
francesco
Are you writing a program or typing commands in the command window?
If it's a program, you need to define the variable usinga letter rather than a number. For example, !q not !3.
If it's the command window, just type the sample you want directly,
sample s2 6 2371
