How to put a correlogram in word?
Posted: Tue Nov 02, 2010 5:57 am
by Siebe
I need to put a correlogram in word.
I can't copy paste it.
Even when I copy paste it in excell I Lose the graphpart of the tabel.
How can I put the same thing I see in eviews in Word ?
(I use eviews6 student edition)
Re: How to put a correlogram in word?
Posted: Tue Nov 02, 2010 7:53 am
The only real way is to make a screenshot (press print-screen, then paste in Word)
Posted: Tue Jul 14, 2015 1:15 pm
by ehr_ab
There is a very neat way to do so: Highlight the correlogram and copy onto the clipboard. Switch to Word and select "Paste" from the menu bar, then use "Paste Special". If you now select "Paste link" you are offered the option to embed Eviews-Objects. Once you have clicked Ok, the correlogram apperars in Word just like in the Eviews output.
Sometimes the formating of numbers is off. If you double click on the Eviews object in Word, the embeded correlogram is opened in Eviews and you can change the column width in the table, which will typically make the correlogram look ok in Word. Click to close the Eviews table and save the changes. :D
