Importing transposed data
Posted: Wed Oct 27, 2010 9:20 am
by jthodge
I apologize if this is a question with a simple answer or has already been asked.
But I'm trying to import data from an Excel 2007 (*.xlsx) file into an Eviews 7 workfile. The data has a transposed structure (i.e. with series names in the rows of the first column instead of along the first row).
I can't find any option for the import command similar to "t" as in read(b2,t) that I used when reading older versions of Excel files.
Am I missing something simple?
Re: Importing transposed data
Posted: Wed Oct 27, 2010 10:16 am
It doesn't exist. The only way to read transposed data is with the read command, and as you point out, the read command does not support .XLSX
Posted: Wed Oct 27, 2010 10:43 am
by tchaithonov
How about transposing your data in Excel first?
Posted: Wed Oct 27, 2010 11:37 am
by jthodge
The data is transposed in Excel because we have 1500+ variables with annual data over 35 years -- otherwise we'd exceed Excel's 256 column limit.
We'll probably just convert the xlsx files to the old xls format and use the read command.
A transpose option in the import command would be a nice feature in future versions of Eviews.
Posted: Wed Oct 27, 2010 11:40 am
It is actually quite tricky to do, but we get requests for it so often, we'll probably allocate some resources to it. Maybe only for Excel files though.
Posted: Wed Oct 27, 2010 12:53 pm
by tchaithonov
The xlsx file format supports up to 65536 columns and 1048576 rows. It should be quite easy to handle a 1500+ by 35 dataset.
Posted: Thu Oct 28, 2010 7:26 am
by jthodge
Thanks tchaithonov.
I've been running my Excel 2007 in compatibility mode, which only has columns from A to IV (i.e. 256 columns). But when opening an .xlsx file, I now see that the columns range from A to XFD (i.e. 16,384 columns).
So no need to transpose my data anymore!
