Error while estimating VAR
Posted: Wed Oct 27, 2010 3:15 am
Dear Eviews veterans,
Using Eviews 6 I ran into the error "Unsufficient number of observations to estimate 9 coeficients per equation in VAR" while trying to estimate a VAR.
My data concerns multiple quotes per second for two hypothetical exchanges. I took the data from the NYSE TAQ database. While they TAQ explained me the time-stamp is only available per second, they did confirm the quotes are in chronological order. The data looks more or less like this:
(Example bids)
DATE TIME BID NYSE BID NON NYSE
03-22-2009 10:30:45 4.67 NA
03-22-2009 10:30:47 4.66 NA
03-22-2009 10:30:47 NA 4.65
03-22-2009 10:30:47 4.67 NA
03-22-2009 10:30:48 NA 4.65
I am researching the responses these markets give to eachother. So how fast do markets adjust, using how many lags. As the data is not available with a more detailed, frequent timestamp I thought this can only be done in Eviews by estimating a VAR model. I think the error I run into has to do with the NA´s turning up in the data as a VAR estimation requires a common, continuous sample for two series (say stock quotes per day). I do not know however how to fix this here. I suppose restructuring the two series to become one should work, but then you don´t have two series anymore.
Any suggestions? Please let me know if I need to be more more specific.
Thank you very much!
(Example bids)
